Question about Lexmark T520 Laser Printer
What is a rare door of a printer? - Lexmark T520 Laser Printer
How do I fix this paper jam2
Dear
Open and close the front door. The jammed paper
automatically exits the machine.or gently pull the paper out of the output tray.
If there is any resistance and the paper does not
move when you pull, or if you cannot see the paper
in the output tray, open the rear door by pulling the
tab on it.Remove the jammed paper by gently pulling it
straight out.Close the rear door.
Some times it may happen if machine gets ready and after one page print it shows jam2 , then check the lever for jam2 sensor on the top of fusser, the spring may dislocated or lever may broken(rare).
Thanks.
Feb 13, 2015 | Office Equipment & Supplies
Paper jam in HP 1200 printer
Hi,Make sure you got every single piece in there, and if you can't get it to work, just hard reset it. Unplug it from the wall wait 5 seconds, plug it back in. Should be good as new.
The LaserJet 1200 has two paper inputs, a regular paper tray and a priority input tray that is used for envelopes, labels and transparencies.
Paper jams rarely happen with the HP LaserJet 1200. If you can see paper sticking out of the input or output tray, try to remove it gently. If you encounter resistance or if the page tears, turn off the lights in the room to avoid exposing the toner to light. Open the toner door, which is above the paper tray, and the output door, and rotate the green levers down. At this point, you might be able to remove the jammed paper. If not, remove the toner cartridge.
Grasp the page in both hands and gently pull it free. Replace the toner cartridge and close the doors. The cartridge and the levers will slide back into place.
Hope that helps..
Mar 15, 2011 | HP LaserJet 1200 Printer
We have a Sharp AL-1642CS Copier machine. That currently isn't working. What does a CH code mean?
CH code = Toner Cartridge is missing or not installed properly. In rare cases it is a defective toner cartridge. Also double check the right side and front doors proper closure.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1642CS Copier
Printer Displays Paper Jam , Clear Paper Jam and Press OK. There is No paper Jam, No paper or torn pieces of paper in the Printer. The Printer is very rarely Used and is almost Brand New . (about 15 months...
Frequently this problem is caused by dirty feed rollers. Even dust accumulated inside a printer rarely used can cause this error. Sometime a door is ajar or not seated correctly. See this HP support article for information on how to resolve it. You may also need to refer here and here.
For other issue with your printer, or to pursue other self-help options, see the HP home support site for your model here. & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Says the back door is open but it is not will not work
When you open the back door there is a black guide that snaps in place covering the fuser. There is a black rod near the center that has a sensor flag on the right side. That flag goes thru a hole on the right into a sensor. That rod has a spring attached. If the rod is broken or the spring is missing you will get that error. On rare occasions the main logic board is bad and needs replacement.
Jan 07, 2010 | Brother DCP-7020 All-In-One Laser Printer
The message 'waste ink absorber' nearly full appears when I try to print from my Canon Pixma iP2000 printer
Hi
Unless you are complelty happy taking items like this apart i would suggest taking it to a local qualified computer shop or repair centre. The waste tank or absorber is a collection of all the waste ink that has ever occured when cleaning the printheads or even charging cartridges when its had new cartridges fitted.
Unfortunetly it is rarely just a case of replacing the pads or tank but also normally requires the system to be reset to prevent the printer halting altogether.
Thanks
Taz
Oct 23, 2009 | Canon PIXMA iP2000 InkJet Printer
I need to find the manual release for the trunk on a 1996 jaguar xj6. I looked in the glove box and its not in there. Any suggestions?
The other places i've seen before are on the floor in front of the seat near the door, under the dash on either driver or passenger side, on the door panel, and in some rare cases inside the fuel door near the gas cap. Also in some rare cases, it hidden somewhere in the center console either near the ash tray, or in the little compartment in the arm rest.
Jul 08, 2009 | Jaguar XJ6 Cars & Trucks
After adding ink cartridge printer stopped working
Parts for any ink jet printer are rare due to the low price of the machines. Technicians rarely repair them for the same reason. Who would want pay a technician $75.00 to repair a $100.00 printer? Consequently, parts generally not available beyond a few major sub-assemblies.
Feb 28, 2009 | Dell 966 All-In-One InkJet Printer
Paper Jam/Kyocera C850/C850D
There will be a piece of paper stuck in there follow the instructions again opening every door on the left side. If there is not some paper the likely thing is that the paper sensor is jammed open or the light reflector sensor is dirty or the last thing is one of the sensors are faulty.
But I know these machines very well and the sensors rarely go faulty so I'm 98% sure there will be just a small piece of paper stuck in there. (It may be between the two doors or stuck behind a guide.
Oct 18, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
Printer C760
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Aug 13, 2007 | Lexmark C760 Laser Printer
Lexmark T520 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
