Question about Intel D865GBF Motherboard
I took off my led,power,and harddisk led on the motherboard to clean up, but was not able to connect it.
  • Intel Master
  • 32,281 Answers
LEDs are polarity sensitive.. If you have plugged it back on the same connector and it does not light up then swap the connectors around. ie turn the connector around 180 degrees.
Posted on Mar 25, 2011
One day, when i clean my system box that i take out the pannel wires from the board .these are power led,hd led etc....after that when i set up those wire i can not use my computer computer .my destop...
Hello aunglina6
As i can see from the picture of your motherboard the connections are at the bottom close to the battery. it looks like this
o o o o 1 2 3 4
o o o o o 5 6 7 8 9
this is just to give you the idea how it is set up.
9 is no connection
8 + 7 is reset switch, 6 + 5 is hard disk LED with 5 the positive of + side.
1 + 2 is power LED with 1 the positive or + side, 3 + 4 is the power switch.
with the reset and the power switch don't worry about the positive or + side. it makes no difference.
good luck.
please leave comment if this was helpful
Jan 01, 2011 | ECS RS400-A (V1.0) Motherboard
I cleaned my pc, and disconected the wires that are right downside corner. I cant remember how to put them back rightly. Any help? hdd led power led + power led - power switch (sw) reset switch (sw)
H57H-AM2 v2 Motherboard in a Gateway DX4840 wire connections for Front Panel are shown here in Photo. I took them before I disconnected mine so it works.3_3_2012_12_10_44_pm.jpg3_3_2012_12_10_56_pm.jpg
Jun 15, 2010 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
I have a t3985 emachine that won't power up. I've opened the case and vacuumed it, took the power supply out vacuumed it. Plug in shows green led on motherboard. i'm wondering if it is the pwr sw. i...
If you carefully take a screw driver and short the two power switch pins together it should start. Did it work before you cleaned it? On the connector itself it should say power sw.
Apr 07, 2010 | Dell (E210882) Motherboard
Can't turn on just hang
if u changed the BIOS battery on the motherboard and havnt re installed the BIOS it Wont Work.....
Mar 24, 2010 | Acer Aspire T310 PC Desktop
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
I have a Intel D865GLC and it will not boot! The green led light on the motherboard is lightning and the CPU-fan is rotating but there is no screen on the monitor and the computer is not boot A have tried...
Refix RAM memory.
Then reattch both.
Nov 13, 2009 | Intel D865GLCLK Motherboard
I removed the connections on my motherboard and i forgot the connections of the front panel
on your motherboard you will find these connections (each motherboard varies) just put the corresponding cables to the pins. it will tell you which is which on the end of the cable.
let me know if you get stuck
Jul 15, 2009 | Computers & Internet
How to connect my led lights[that is the red nd green light ] with my 865 chipset''......where r those pins on the motherboard ??
in *********** board where the reset & power botton is connected same place you can find HDD LED for Harddisk and Power LED for power, please be carefull with the sign designation about (+) and (-) it is indicated in the board and pin.
Jun 12, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Intel D865GBF Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
