Question about Refrigerators
Hi, My name is Andreea.I have a fridge Samsung side by side RSH3DBPE and i detected a problem.From few days i heard a strog noise from the back of the fridge some days( like the motor is making,but i don't know if it is) then it stops.And sometimes when i open the fridge door i hear a noise like something that is spining and the noise is lower and lower and then stops.If i close the door and imediatly open the noise is not hearing again.But if i open the door after a long period of time i hear the same noise. Thank you
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Mar 25, 2011
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
The right side of the fridge is not cooling well. the freezer is fine, but it also making a strange noise
Hi and welcome to FixYa, I am Kelly.
That strange noise your hearing is probably the fan blades of the evaporator fan striking ice build up on the evaportor coils. This symptom is typical of and automadefrosting problem.... or someone left the freezer door open for a very long period.
You can try doing a manual defrost by unplugging the unit and place a fan blowing into the freezer compartment / compartment making noise for about 2 hours. (makes a water mess) After 2 hours tend to the water mess and restart the unit. Most likely the noise you heard will be gone... for a few days. If you have an automatic defrost problem the noise will return in about 72 hours as the ice build up gets larger on the evaporator coils.
Depending on date of manufacture this unit can have either a manual defrost timer or an adaptive defrost control board that controls the automatic defrost. .
Thanks for choosing FixYa,
Kelly
Nov 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
My printer samsung CLX-3160FN, does a strog
There is mechanical problem with your printer so that printer need servicing.
Feb 24, 2010 | Samsung CLX 3160fn All-In-One Printer
Fridge is not working
I had to pull off both back inside freezer panels, unplug, and completely defrost the freezer.  I am getting a refund.
Jun 14, 2009 | Samsung RB215LASH
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
465 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
