Question about Amana AMV4204A Microwave Oven
AMV420AA Microwave Oven will intermittently display 77:77
Microwave will display77:77 push power level or start on screen. when numbers are coming on screen it beeps each time. then it may clear itself independently and display the same thing again. Sometimes it will not stop. When i open the door and then hit stop, it erases, but will go back to doing what it was doing. Occassionally, it will not let you erase the numbers. i have turned the machine off for a while...unplugged it. It will go days without doing this or perhaps months...could a neighbors video machine be interfering?
  • Amana Master
  • 8,968 Answers
It sounds like the "7" pad on your keypad is shorting.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 03, 2008
How do I set the power level
Enter the cooking time. Press the Power Level button until the desired level is displayed - Level 1 = 100%, Level 2 = 90%, ... Level 10 = 10%.). Press Start button.
Dec 10, 2015 | Sharp Carousel R530EST Microwave Oven
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
How do I change the power setting
you have to enter your cooking time and THEN hit the "power level" button. Most likely, the display will read "the current power level is set to 10" or something like that. just go ahead and put in the number for the percent you want.
For example, hit 5 for 50% power. Then, hit "start."
eat
Aug 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
The microwave doesn't come on and when you push
I'm assuming this is model number MH2175XSQ1.
F6 means the cook power relay on the control circuit board is intermittently shorting.
We regularly repair these controllers nationwide by mail for $39.95 postpaid with a one year guarantee. Details are here.
Or you can order a new control board ("microcomputer" part number W10166798) here for $74.30 plus shipping.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below), take out the defective board and install the new one.
Some connectors on the relays may have a lock:
Jul 10, 2010 | Whirlpool MH2175XS Microwave Oven
Whirlpool Microwave Oven GH9185XLB1
You may have a bad control board. Have you tried unplugging the oven and then reapplying poqwer afterwards? Manytimes , when elcetronic control logic gets corrupt, a power down/up reset clears the problem. If it continues, I would consider replacing the control board..Here is a link to the circuit board you might consider replacing.. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059895&PPStack=1
These kind of things are generally trial and error and there is no guarantee that this will be the solution to your specific problem..
Hope this helps...
Sep 09, 2008 | Whirlpool GH9185XL Microwave Oven
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Panasonic NN-S541 Microwave Oven
Amana AMV4204A Microwave Oven Logo
95 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
