Question about Rosewill R900J 19" Flat Panel LCD Monitor
If one computer monitor is becomes off and on in by second whats the problems?
  • 11,361 Answers
It does the same thing when attached to another PC?
Common problem in LCD monitors are due to bad capacitors in the power supply, you can Google that.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 25, 2011
My monitor works good for a second when i start it and then the screen becomes dark but you can see that it is still working. You see a little bit what is on the screen.
The problem can be caused by failed capacitors in the power supply, inverter circuits, lamps. You need to open it up and inpsect inside for bad caps first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps/lamps/inveter: http://s807.photobucket.com/home/budm/allalbums
Mar 17, 2010 | HP w1907 LCD Monitor
When i start the moniter its lights for seconds
The problem can be bad power supply due to bad caps, bad backlights inverter, or bad lamps. You need to open it up tell us what you see inside first, see example of faile monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Computers & Internet
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
Junky speakers
One of the speakers is blown so unless you can find a replacement speaker for the blown one then you have to either buy a set of other speakers to replace the speakers in the monitor or buy speakers you can hook up to output of the computer.
Jun 18, 2009 | HP Compaq WF1907 Monitor
How can a dummy degauss this problem?
Degaussing is only an issue with CRT monitors, I'm afraid the monitor is going.
Apr 01, 2009 | Westinghouse L1928NV Monitor
The monitor get on for a second, then it goes black
sounds like a blown backlight (the TFT screen is lit from behind by thin white flourescenet type tubes,
if these become faulty then you cannot see the display output as it is no longer lit from behind
Mar 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Studioworks 552V 15
It is standy by problom.Find the problom instandy by section
Aug 04, 2008 | LG Studioworks 552V 15" CRT Monitor
HP 19 IN. LCD MONITOR
its so simple problem on screen what come no signal rigt
so u have to do this just chek ur monitor cable its not pulg in cpu
so reconnet ur monitor cable in your cpu
thnx using fixya
Mar 30, 2008 | HP f1905 19" Flat Panel LCD Monitor
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
21 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
