Question about Clarion XMD3-RET AM/FM MARINE CD PLAYER
XMD3 I bought a second hand boat with this radio , not working , do you have an installation schema ?Thanks
  • 391 Answers
Hello there ,firstly at the rear of the radio you will see two plastic blocks top block is your power in )secondly bottom block is your( audio ) sound these wires are colour coded for front and rear speakers ,your dc power which cannot be over 13.8v black and red wire on top block you have a socket to the right this will be for the antenna ,also check the fuse line before switching on hope this helps you
goodluck
Posted on Mar 25, 2011
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
Hello, i have a clarion xmd3, i bought it in 2004 and have a sirrius add on sara radio reciever. im trying to resubscribe for service. i need the radio to display sat radio id#. went to clarion web site...
You can get the # right off the Sirius unit (it's on a sticker on it - SID#).
Also try going between channels 1 and 184 (IE go track/tune down) it may show up then.
If not press and hold the T button for longer than 1 second. Then use the track up/down buttons to scroll through the menu. There should be a screen that will show Sirius or Sat ID or something to that effect. When you see that press the up or down button, or play pause and it should display it.
Let me know if that works.
Dec 11, 2010 | Clarion XMD3
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
Can't get sound to come out of rear speakers.
go to the menu and select fade f/r then adjust until happy should be in the middel
Jun 13, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
XMD3 unable to select anything but satellite
i have had several problems like that. It is probably one of your controllers especially if you have the old oval ones. Go to the back of the stereo and unplug them, then plug one in at a time and isolate the problem to a controller.
Jul 19, 2008 | Clarion XMD3
NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Oct 19, 2007 | Clarion XMD3
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Car Audio & Video Logo
241 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
