My Telefunken Split Unit Aircon model TAS 120B flashes "CF" after it has been switched off. What does this mean? It seems to be working well with no visable problems. It is only 4 months old.
Telefunken tas120 airconditioner runs for 30 minutes and then switches off for 5minutes and then keeps on switching on and off at shorter periods. I have changed the sensor with my other machine of the same make and model but although it works in the one machine it has not solved the problem. What other part can I swop.
Thanks
Posted on Feb 17, 2014
5 Suggested Answers
  • 23 Answers
SOURCE: i have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Posted on Jun 15, 2009
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
SOURCE: Telefunken TAS 180E aircon unit, After startup the unit runs for
have 9000btu recently changed the compressor,cleaned the system,installed a drier,runs for 2days and start icing up on the
discharge,like it short of gas ,stop the unit for a while check the gas its shows 390kpa.what could be causing it not to work properly
Posted on Feb 15, 2011
SOURCE: my carrier split type non-inverter aircon always blinking
I got the same problem in Samsung aircon. The unit I purchsed died slowly. After that Samsung replaced it with the one have the same problem. They are swearing that the green light blinking problem as a normal function and refusing to fix. Their user manual says it is a problem. I think the affected consumers should join hands to take legal action against this scam.
Posted on Dec 20, 2011
What does a flashing light mean?
a flashing light could mean any number of things. normal operation, number of communicating components, a minor alert such as a filter change or major alarm like pressure error or control board problems. first we would need the number of flashes and /or sequence of multiple flashes AND the model number of your "split heat pump!"
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 13, 2018 | Heating & Cooling
I have an TCL aircon and it comes up with a message E2 and then switches it self off, the aircon is about 8 months old can someone help me with whats wrong with it please and thanks :)
TCL provide a 5 year warranty. i would suggest you contact the nearest Agent. An E2 error from what I remember is an overheat / overpressure problem. Check your filters on the indoor unit. If they are blocked, this error could appear and it wont be a warrantable fault...
Jul 14, 2011 | Turboair TAS-24H Split System Air...
My air conditioner blows air but it is not cold? What can be the problem?
It could lacking refrigerants (freon). contact your local aircon tech; I do not recommend DIY.
Hope this helps!
Fix14
Jun 16, 2010 | Turboair TAS-24H Split System Air...
Indoor unit flashes 5 times. error code meaning?
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Dec 31, 2009 | Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
