Computers & Internet Logo
Anonymous Posted on Mar 25, 2011
Front panell power&reset button&usb jacks to mother board
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Mar 25, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541848
Points
28391
If you need to know where they go, download a manual on your motherboard from the manufacturer.
2answers
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
1helpful
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
2answers
1helpful
3answers
Can you help me locate the power switch and reset slot on my samsung polaris 33 motherboard?
I told another guy the same thing about a different board. Samsung doesn't even acknowledge mother boards because they sell generic boards to pc makers. Best way is to take the power wire from the case & start at the pins closest to you on the front panel connectors (fpnl on the board) & try each set of pins one at a time until it turns on when you hit the power switch. The reset is usually right across from the power. I've had to do this numerous times,so don't worry about frying anything.
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
1helpful
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
5helpful
2answers
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
3helpful
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on [email protected]
No sound from front headphones
check your speaker is good and it i inerted in the correct slot and it raise the error of POST so the mother board power had some problem cheak wether the led in the mother board glows properly once it correct check with your board input power +-5,using your multimeter.or else there is a problem in your smps
1helpful
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Grand Canyon Tech
Grand Canyon Tech
