Question about Mad Dog Multimedia Computers & Internet
When I try to burn a DVD or CD my Multi Media is telling me to connect a burner and restart the Player. I have a burner connected, and it has been working up until about 4 days ago, could you please give me an idea on what is wrong Thankyou Shirley
  • Mad Dog Mult... Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 25, 2011
I am trying to burn a CD and it says to connect to a burner
Put the CD from yesterday into the CD-burner, and open the CD with Windows Media Player. Does it open?
Nov 14, 2009 | Microsoft Windows Media Player
I have a dell optiplex755 and i have created a playlist in windows media and when i try to burn a disk it tells me to connect a burner and restart. i have not tried to burn a disk before on this computer...
Look closely right at the front of the CD drive - does it say CD ROM or CD/RW? Or possibly DVD ROM or DVD/RW?
If you have a drive that says "ROM" on the front, it's not a burner.
If your drive does say "RW" then it may not be enabled. Go to My Computer (or Computer, depending on if you have Vista or 7) and right click on the CD drive. Choose properties, and look through the tabs to make sure that drive is enabled for recording.
Hope this helps! If so, please leave a rating!
Oct 17, 2009 | Microsoft Windows Media Player
I am having a problem with my hp cd/dvd burner drive. when I go into wmp and try to burn something it tells me to connect a burner and restart the player, please help
What version of Windows Media Player are you currently using? If it is not up-to-date, try updating Windows and Windows Media Player. Then attempt to create the CD.
If that doesn't work, try updating the driver for your CD-ROM drive. Navigate to HP's Support Site, type in your machine model and search fot the CD drivers there. Update the necessary drivers and attempt to create the CD once more.
I hope I was able to help. Good luck!
Aug 08, 2009 | HP Pavilion Media Center m9340f Desktop PC
Media player cannot detect burner anymore
Check the Manufacturer's website for a Download of the CD Drive Drivers. If you have a Software recovery application on your computer (Many HP and Dell Computers have this) the drivers may already be on your system, you may just need to re-install them. If re-installing the driver's doesn't work, I don't know what to tell you, unless your drive has gone bad.
Jun 19, 2009 | Compaq (249666-001) CD-RW/DVD-ROM (Combo)...
When i try to burn a cd windows media player says connect a burner and restart
If you are running nero or Roxio then disable it first. Roxio takes over the burning capabilities exclusively. You will also have to reset the device to allow WINDOWS to burn CD's. Also make note that amediplayer burns WMA files that some players won't read.
Jun 13, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
Connect burner and restart Windows Media Player
Run REGEDIT
Select {4D36E965-E325-11CE-BFC1-08002BE10318} at the end of the following path:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters do an Edit/Delete
In right pane select LowerFilters do an Edit/Delete
Exit REGEDIT
Right click MY COMPUTER
Properties
Hardware
Device Manager
Uninstall CD/DVD player/burner
Restart the machine and it will find and reinstall the burner
NOTE: if you’re uncomfortable deleting registry entries, rename them (e.g., w/ “.SAV” extension)
Jun 06, 2009 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Connect a burner and restart the player
Open REGEDIT
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters - do an Edit/Delete
In right pane select LowerFilters - do an Edit/Delete
Exit REGEDIT
Properties
Hardware
Device Manager
Uninstall your CD/DVD player/burner
Restart the machine - it will find and reinstall your burner and you'll be good to go
Note: if your uncomfortable deleting registry entries, rename them (e.g., w/ ".SAV" extension)
May 19, 2009 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Media player says that it cant find the burner
I guess you have a Read-Only drive - ROM. You need a CD/DVD RW drive for burning.
Dec 31, 2008 | Samsung SD 616E (729507925578) Internal...
Computers & Internet Logo
63 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
