Question about Dishwashers
Have just got a second hand belling idw604 dishwasher, when i turn it on the programe lights flash up then go off, i dont know how to make it work as i dont have a manual, am i being thick?
  • 822 Answers
Try the belling website.....then customer support........should be able to download manual..
cheers
Posted on Mar 25, 2011
  • roberttho16 May 29, 2011
    hi, i have had my IDW604 from new and having cleaned the jets today I have same problem. the power is on, then all 5 programme lights initailly light up then immediately go off and you cannt select a programme. I have tried switching power off and the manual does not advise anything
I have a belling IDW604 integrated dishwasher which is not heating the water
An open element will have voltage present and still not operate. Use an ohm meter to test it.
Dec 21, 2015 | Belling Dishwashers
Belling IDW604 wont heat water
Check heater for continuity, thermostat and control timer
May 09, 2012 | Belling 24 in. IDW603 Built-in Dishwasher
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Dec 27, 2009 | Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Belling dishwasher IDW604
there is a small plastic catch in the door side of lock which loks arround the bar on the washer side of the lock somtimes it stays in you can click it out with a knife or simillar sould work fine after that
Dec 21, 2007 | Belling 24 in. IDW603 Built-in Dishwasher
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Dishwashers Logo
458 people viewed this question
Top Dishwashers Experts
