Was looking for part number breakdown trying to find out what the btuh rating for this compresser is pt # Z2-5416A20003J-89WA/C this is a winnero compresser sold by lg also was needing the same info for a bristal compressor h29b28ubcx thanks
2 Suggested Answers
  • 232 Answers
SOURCE: i need a part break down on a tempstar unit model
http://icpindexing.mqgroup.com/documents/086477/46204110701.pdf
Posted on Sep 12, 2009
Where is the fuse for the rear defroster for a 2005 P.T. Cruiser ?
Look at number 15 on the diagram that should be it.
Pls rate. Thank you.
Oct 04, 2016 | 2005 Chrysler PT Cruiser
How many pounds of reon do you put In 2011 Rheem Classic packaged ac unit
look on the mane plate on outside unit... has voltage ratings model serial type of freon factory charge etc.
Jul 21, 2014 | Rheem Prestige 14 Series 4.0 ton 14.5 SEER...
Pilot will not lite
disconnect pilot line at gas valve if gas there then pilot line or pilot orifice is plugged clear with compressed air reconnect and try again
Nov 08, 2013 | Cozy Enclosed Front Console Heater 70,000...
I have carrier heat and air model numbers 58sx and 38tg what sizes are these
You need more information to get the size. The Carrier 58sx series includes 5 different models: 40 - 41000 BTUH, 60 - 61000 BTUH, 80 - 81000BTUH, 100 - 102000 BTUH, 120 - 122000BTUH. An installation guide for the 58sx is available here: http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/58sx-14si.pdf . The Carrier 38tg has 6 different sizes (020 - 20,000BTUH through 050 - 50,000BTUH). The other sizes are 025, 030, 035, 040 and the capacity is that number multiplied by 1000.)
To determine your model's capacity, look at the full product number. The first three numbers after the 58sx or 38tg will indicate the nominal capacity.
I hope this helps.
Oct 25, 2011 | Heating & Cooling
No problem trying to find out tonnage i would like to know how big a unit i will need when i replace this
This unit is a 3 ton unit
P3RA-10 SEER
3, 4 and 5 Ton Units
Cooling: 32,500 to 55,700 Btuh
P3RA- Cooling Btuh SEER
036K 32,500 10
048K 45,500 10
060K 55,700 10
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Intertherm P3RA-036K Air Conditioner
I have a 2006 PT Cruiser. It keeps coding a P304. 4th cylinder misfire. I have replaced plugs, wires, coil, upper and lower intake gaskets. Its still coding and now the ck engine light blinks. Any...
CLEAN FUEL INJECTORS SEE IF THAT HELPS.IF NOT COULD HAVE BAD FUEL INJECTOR OR FUEL INJECTOR ELECTRICAL CONNECTOR COULD HAVE A SHORT.DO A COMPRESSION CHECK ON THAT CYLINER COULD ALSO HAVE LOW COMPRESSION DUE TO BAD VALVES OR INTAKE MANIFOLD LEAK AT CYLINDER NUMBER 4.
Jul 12, 2011 | 2002 Chrysler PT Cruiser
I am having a hard time getting my 02 pt cruiser on its compression stroke when i line up all my timing marks what am i doing wrong?
NUMBER 1 PISTON TOP DEAD CENTER WITH DISTRIBUTOR ROTOR POINTING TO NUMBER 1 SPARK PLUG AND BOTH VALVES CLOSED.LOOKING AT TIMING SCALE CRANKSHAFT DAMPER TIMING MARK AT O.ON TIMING SCALE.REMOVE SPARK PLUG NUMBER 1 PLACE FINGER NEAR SPARK PLUG HOLE.WHEN YOU FEEL GUSH OF AIR ENGINE ENTERING COMPRESSION STROKE.SOME MECHANICS USES A SPECIAL WHISTLE WHEN PISTON GET TO COMPRESSION STROKE THE WHISTLE WILL BLOW TO LET YOU KNOW GOING TO COMPRESSION STROKE.
Oct 05, 2010 | Chrysler PT Cruiser Cars & Trucks
I have a Bosch jig saw that I am having trouble getting blades in; I took the saw apart and now I can't get the saw back together. Help
You can try to get a breakdown at Boschtools.com but you will need the exact model number and on the left side there is a link to download a breakdown. Let me know if you need more help and I will try and if I have answered your question would you please rate this response accordingly.
Sep 28, 2009 | Bosch Saws
How to determine horse power of air conditioner
air conditioning units are measured in btu's stands for
(British thermal units)
6,000 BTUh to 10,000 BTUh will cool 400 sq.ft approximately
10,000 BTUh to 16,000 BTUh. will cool about 800 sq.ft approximately
16,000 to 28,000 BTUh will cool 2,000 sq.ft approximately
the idea is more but's the more cooling power it will have.
Aug 20, 2009 | Panasonic CW-XC203EU Air Conditioner
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
