Question about Brunton Helios Stormproof Lighter
Cant seem to get it to fill...should you see the fluid in the site glass?
I have a kubota L2900. No site glass for hydraulics. How do I check the fluid level
Only other way is to remove hydraulic fill cap and inspect from there
Feb 29, 2016 | Cars & Trucks
Where's dip stock for hydroloc fluid on a Kubota L3400 4x4 tractor
As a rule the Kubota L2800/L3400 do not have a dip stick for the hydraulic fluid. To check the fluid level, find the small round site glass that is on the transmission, left side, just in front of the clutch pedal. This sight glass has a level line on it. If the level is low the fluid might not show in the sight glass. If the level is below the line add fluid. The fill port for the Hydraulic fluid is on the back of the tractor just below the level of the seat.
Oct 31, 2014 | Garden
Fill washer fluid 2013 jeep patriot
wind shield washer.
so post a problem.
1: dead.
2: weak
3: leaks (not glass spray but in system)
4: noises. bad.
5: blows the fuse ?
6: what kind to use, fluid.?
7: how high to fill it>?
see , i cant answer.
Nov 25, 2013 | 2009 Jeep Patriot
I have a 99 ford windstar that has had a power steering fluid leak for a while but i went out to drive this morning and its leaking buckets when i turn i cant find a leak the reservoir was covered in fluid...
did you fill it up while it was running if you did you probably overfilled it and when you shut it off it raised up in the reservoir and sprayed out the cap. Fill with vehicle off.
Feb 15, 2011 | 1999 Ford Windstar
HI I HAVE A RENAULT MAGANE 2000 BUT I CANT SEEM TO FIND DIPSTICK TO PUT TRANSMISSION FLUID IN CHEERS
There may be a plug on the front of the box, roughly half way up. You can roughly fill through this. Fill until fluid dribbles out, work the box through the gears a couple of times (engine off), then try to run some more in.if its the same transmission as the scenic it has the DPO automatic it does not have one I must stress this is a rough method and it should really go to a garage for proper levels / top ups ...hope this helps
Sep 10, 2010 | 2000 Renault 181
Hi--i have an 03 tm250 fourstroke enduro spec.kickstart only. does not have a dipstick but has a glass sightglass rightside of engine. also has what seems to be a oil level bolt near kickstart.. is the...
Hi, Peter engine and transmission share the same oil many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
1. Bring the engine up to operating temperature or let idle for 5 minutes.
2. Turn off your engine and let it sit for 2 minutes, this will allow the oil from the top end to drain to the bottom.
3. Hold your bike straight up or on the center stand and wait 2 minutes for the oil in the bottom of the engine to be level in the sight glass.
4. Your oil level should be between the top full mark and the bottom add mark.
5. Never over fill your oil system it will cause problems:
a. oil leaking out of exhaust pipes.
b. oil leaking out of breather pipe/hose.
c. oil carryover into the air cleaner.
6. Your oil site glass must never be completely full drain as necessary.
7. Your oil site glass must never be completely empty add as necessary.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
TM 250F
YZ250f and WR250f Oil Change Instructions YZ WR 250f dirt bike
TM Racing Manuals Spare Parts Manuals Exploded Diagrams
http://www.tmracing.it/public/doc/1628_Motore_4T_250_2003.pdf
TM RACING 250Fi EN Use And Maintenance Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 06, 2017 | 2002 TM Racing E 250 4t
How do i change the transmission fluid for my manual Nissan maxima 1996?i cant seem to find any pictures or diagram on how to change it.
manual transmissions should have a drain plug on or near the bottom of the transmission and a fill plug near the top of the transmission. Remove both plugs and drain gear lube into pan. Replace drain plug. Fill with recommended fluid through top hole and then replace that plug.
Feb 21, 2010 | 1996 Nissan Maxima
Oil change question
motor and tranny filters and so on. I was looking through my manual on SMJ and on here regarding the amount of fluid to refill in the crank case and from what I have read I am coming up with 1.6 quarts according to the board. However when I follow the instructions for refilling I end up with about 875cc or approx 3/4 of a quarts in the frame spar/motor and about the same in the tranny. I am using Mobil 1 4T in the motor and Spetra Gold gear saver in the tranny (80W). Am I doing something wrong or is it supposed to be 1.6 quarts total in the bike (motor and tranny)? When draining the fluids I drain all the ports and clean all the filter completely. The first time I filled the frame spar back up I filled it until it came up about halfway in the frame spar ran the bike for a minute and after it settled for about 5 mins filled it back to the half way mark in the sight glass. This totaled 875cc. The next day I saw the oil didnt appear in the site glass so I filled it again. Needless to say it started spitting oil out the vent tube on the way to work so I read up on it and found that I had probably over filled. The instructions I read though stated to fill the frame spar with 1 quart, start the bike and let it sit. When I went ahead and changed the oil again and refilled it I followed this method and again it was too full (over the top of the site glass). Can someone clarify for me the proceedure. The tranny is pretty straight forward but the motor seems to be a bit more complicated. As of right now I have the oil filled with about 875cc and when it starts up the oil comes up in the frame spar about half way into the site glass. ,Don't feel like your the only guy. Overfilling has happened to just about every owner in some way or another until they learn the trick to checking the oil. I have never had less than 1 qt doing oil changes. It's always somewhere around 1.2 to 1.4 What I do is I lean the bike over to the left and then back to the right to help get most of the oil out. And I let it drip for a long while. When I refill the engine I always add 1 full quart then start the engine for a few seconds and stop it. Then I top it off to the sight glass. The rule of thumb being, never go by what the sight glass says if the bike has been sitting more than 10 minutes. Always check the oil right after you start the motor and shut the engine off. Reason being, the oil will drain out of the frame slowly over time so it makes the sight glass inaccurate the longer the bike sits. And every bike is different in how quickly the oil drains out of the frame. _________________ ,,,
Nov 10, 2008 | 2007 ATK 450 Motard
Saturn 2001 transmission
this vehicle has no dipstick, supposed to be maintained by professional only. there is the fill cap on the drivers side, between the fuse box and engine. it is red and more towards the bottom. i imagine you can atleast see the fluid status.
Oct 14, 2008 | 2000 Saturn SL
Power steering fluid
I have a '98 Grand Voyager 3.3 L V-6, it's located on the passenger side fender at about the middle of the engine compartment, should be clearly labeled. countrycurt0
Oct 13, 2008 | 1999 Dodge Grand Caravan
Brunton Helios Stormproof Lighter Logo
19 people viewed this question
Top Brunton Sport & Outdoor - Others Experts
Bill Eager
Are you a Brunton Sport and Outdoor - Other Expert? Answer questions, earn points and help others
