SOURCE: Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
SOURCE: Re: Error Code 5010
it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
SOURCE: MY Canon Pixma MP 500 Printer won't Print.
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
SOURCE: I have the Canon MP 480 I have an error code of
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
SOURCE: service error 6A00 in my canon ip 5200 printer. what should i do
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
