Question about Bosch 5" Small Angle Grinder
PWS 8-125 (european 800W 5"
    Sergeant:
    Champion:
  • 242 Answers
Yep - probably dust build up - have you tried one of those cans of compressed air used for blowing stuff out of computers and stuff. They have a bit more blow than you and a small nozzle to get right it.
Posted on Mar 25, 2011
Fixing bad motors in dewalt angle grinders power tools
it would be much better if you bought a new one because it would be cheaper
Jul 04, 2014 | Dewalt DW824 5" Electric Angle Grinder
Unit has hard time starting, need to turn wheel, only runs at slow speed
you have a problem with the bearings or the motor/brushes are burnt. Does this tool arc when running. If so I would check the brushes first, unplug the tool and remove them and while they are out rotate the motor slowly and look at the commutator bars for excessive discoloration or unusual wear.
May 08, 2011 | Makita 9565CV 5" Variable Speed Angle...
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
Plug in makita die grinder, turn on, runs for 2 to 3 seconds and pops breaker. It is a variable speed grinder
does it run freely?as in not seem to be lugging from bad bearings in the motor shaft,then check the speed control board for a shorted triac/scr transistor
Mar 25, 2011 | Makita 14" Die Grinder
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
Grinder is giving out sparks from back and giving burnt smell
Brushes. The brushes have worn down to the contacts or worse, to the springs.
The good news, brushes are inexpensive.
If you are mechanically inclined and comfortable dismantling power tools of medium to high complexity this is something you can do at home.
HOWEVER, if you have even the most minimal reservation, I would recommend bringing it to a shop so an experienced repair person can replace them. For example, if you need instructions on how to re-assemble planetary drive gears, bring it to a shop.
The procedure should be reasonably priced and quickly accomplished.
Best regards
Mike
Apr 07, 2010 | Makita 9565CV 5" Variable Speed Angle...
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
I want to learn how to repair or rebuild makita grinders
i worked for makita factory service center as a senior technician and never heard of a video...
Apr 09, 2009 | Makita 9565CV 5" Variable Speed Angle...
My makita angle grinder is making a crackling sound I replaced the brushes, but it is still making the same sound
OK one of a couple things the brushes night need seated with a stone for this purpose or the armature or field is bad. Remove the brushes and look at the commutator thru the tube and see if there is a bar or 2 that has discoloration or is raised. Let me know if I can help further.
Mar 06, 2009 | Makita 9565CV 5" Variable Speed Angle...
Bosch 5" Small Angle Grinder Logo
138 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
