Question about LG LS-L1210CL Mini Split Air Conditioner
If power go OFF and camme again why the air conditioner not came ON automatical
Why the indoor ''on'' and''off'' automaticly
Posted on Apr 13, 2011
My AC gets automatically turn it off and flashing timer bulb.
First check the following first.
1. Keep the temp between 24 to 20 degree celcious
2. Check the air filters are cleaned
3. Check the power is correct.. if there is fluctuvation use stabiliser or booster
4. Check condensor coil is cleaned.
Conclusion. Every a/c must be cleaned once in 3 months and air filters are to be cleaned by every week.
Sep 11, 2015 | Heating & Cooling
MY WINDOW UNIT JUST STOPPED WORKING AND NOW IT IS READING E1. HOW DO I GET IT TO WORK AGAIN?
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
My power went out after the power came back on my air conditioner reads e1
E1 might be a stuck key on the keypad... they are sometimes flakey .. maybe water getting into the keypad ... at any rate the remote control usually still works .. eventually sometimes the key pad starts to work again (maybe when it dries out)
So, based on solutions from those other sites, I pulled off the front panel, turned it over and removed the 4 screws from the back of the control pad (not the six screws on the outer perimeter). I looked for a stuck button but did not find one. I just pushed all the buttons a few times in case one was stuck (as suggested on other sites) and that did it!
Hope helps.
Jun 11, 2011 | Haier ESA3109 WallWindow Air Conditioner
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Sometimes the mitsubishi Mr.slim unit is automatically fully off and an icon is on the remote control is blinking..what is the problem?
Check for timer setting you have done. If it is, reset the power to unit and also remove battery in remote and reset it. If still problem write again plz.
Dec 13, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
HOW WE CAN SET THE SPLIT UNIT TO BE WITH POWER SUPPLY RECOVERY FUNCTION? I MEAN WHEN POWER SUPPLY TRIP AND RESET AGAIN WE WANT THE UNIT TO START AUTOMATICLY WITHOUT PRESS ON SWITCH
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 15, 2010 | Mitsubishi Heating & Cooling
Shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
May 17, 2010 | Dometic Rooftop RV Air Conditioner
04 lancer power loss
check your plug wires I had same problem, turned out to be a bad wire.
Aug 01, 2009 | 2003 Mitsubishi Lancer
LG LS-L1210CL Mini Split Air Conditioner Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
