Question about Linksys Wireless-G WRT54G Router
My Sony Vaio running Windows 7 64 bit cannot see my WRT54G wireless network, but it sees neighbours networks. My Apple laptop, XP laptop and games console all connect to the wireless network fine. I've deleted and reinstalled the Vaio wireless card drivers and deleted and reinstalled the Vaio networking utility. I've downloaded the latest firmware from Linksys/Cisco and installed that.
  • m498 Mar 25, 2011
    Broadcasting my SSID is enabled and it is visible to my other computers and to my neighbours.
  • m498 Apr 14, 2011
    I have managed to isolate the problem. It seems to be Windows 7's inability to handle MAC address filtering consistently. Turning MAC address filtering off has enabled the Windows 7 device to see and connect to the wireless network.
  • 90 Answers
Check Ur Wi-Fi device put to Visible mode or hidden .. If its hidden U need to configure the Wi-Fi manually otherwise make it visible and configure.
Posted on Mar 25, 2011
  • m498 Apr 14, 2011
    I have managed to isolate the problem. Windows 7 is unable to handle MAC address filtering consistently and turning this off has enabled my Sony to see use the wireless network.
I have a sony vaio laptop do i need a wireless card.
Almost all laptops being manufactured even 10 years ago has built it wireless card. I believe yours have built in one and no need to buy an external wireless card.
To further verify if you have it installed, you can check in in the Device Manager under Network adapters (if the wireless card driver is installed). To bring this up, follow the steps below.
For Windows XP:
Start -> Run -> devmgmt.msc (Type in the box) -> Expand "Network adapters" (You should see wireless and ethernet adapters listed)
For Windows Vista and 7
Start -> devmgmt.msc (Type in the start search box) -> Expand "Network adapters" (You should see wireless and ethernet adapters listed)
If you want to further check if you really have the wireless card installed, please post the make and model of your laptop.
Hope this helps.
Jun 26, 2011 | Sony Computers & Internet
I have a sony vaio about four years old. I have had no problems connecting to unsecured wireless networks and software secured networks, but cannot connect to a router secured network even when I have the...
Try removing the preferred Network and try to scan and connect
ON Windows XP
Start --> Run -->ncpa.cpl -->Right Click on the Wireless Network connection Icon -->Click on Properties At the top click on Wireless network tab --> Remove Your Network name if you found there then Try to scan and connect again will work
Aug 05, 2010 | Sony VAIO (PCWA-A200)
Print jobs don't get into a queue when print server is offline
you must repair sharing to your all network,if not work you must check cable Lan connection try this.good luck
Apr 24, 2010 | Microsoft Windows XP Home Edition
Wireless issues
Try using WEP key encryption comparitively it is more stable
Nov 28, 2009 | Sony VAIO PCG-K35 Notebook
Sony Vaio XP Downgradation Wireless problem
Same Problem I am facing too. I am also having SONY VAIO VGN-CS21GN
Aug 17, 2009 | Intel PRO/Wireless 3945ABG Network...
Wireless network on sony vaio
Sir,
check the links below and go through the sites......u have a solution
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 07, 2009 | Sony Computers & Internet
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Sony Vaio laptop unable to detect wireless access point
CompuLayne: Hello bluebells953
Netgear is quite tricky as is with all other routers, but I don't think the router is your problem. Try to do the following.
1) Turn off Vaio laptop
2) unplug router
3) unplug modem
4) plug back in modem - wait for it to boot up
5) plug back in router - wait for it to boot up
6) turn back on the Vaio - log in and see if it sees the SID. If it isn't broadcasting, you might have to enter it in manually and select connect to non broadcasting network
www.compulayne.com
www.compulayne.com : "We Fix Computers in 48Hrs! : We Are That Easy"
Feb 28, 2009 | Sony Computers & Internet
Loss of Connectivity
Libog1 - did you install any additional wireless software to connect to the router (Linksys software) or are you just allowing Vista to connect directly using Windows' built-in wireless management?
Ben
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Wireless network connection
you may need to run the network wizard, as your sony may not be set up as using a gateway type connection and may be instructing other pcs to connect via itself and not on the network.
Jul 31, 2007 | Sony VAIO VGN-SZ340 Notebook
Linksys Wireless-G WRT54G Router Logo
153 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
