Question about Polaris Trail Boss ATV
Need to know where starter is on 99 trailblazer 250
    Problem Solver:
It should be located underneath the back side of the engine, you may have to remove a skid plate to find it, Follow the big red wire to it.
Posted on Mar 29, 2012
I have,a polaris trailblazer 250. I had to pull start it because it seemed the battery was bad. Bought and installed a new battery and,still won't start. Any ideas....
If it will not spin over, check for battery voltage to the starter.If there is 12 volt to the battery connection on the starter while the start button is being pressed then the starter has gone bad. If there is not any voltage to the starter while pressing the start button, check for blown fuses and the starter solenoid,usually under the seat near the battery, and starter relay,also near the battery.
Feb 25, 2015 | ATVs
Trailblazer 250 wont start
check/change, Battery, spark plug, remove air filter, use starter fluid, drain all old gas. use premium new gas. usecarb cleaner...should run,.
Mar 28, 2014 | Polaris ATV
99 kawasaki ninja EX250 motor swap for a 98 NINJA EX250 MOTOR
I would try charging the battery. Take it off and put it on a slow trickle charge overnight. Batteries usually only last 3-4 years if it is an acid battery.
Nov 27, 2011 | kawasaki Kawasaki Ex250f11 Ninja 250r...
2004 trailblazer 4.2 newer battery wont start when turning the key it does not even try to turn over when turning the key all the lights on the cluster go out and then when you let off the key they...
By your description, it sounds like the starter motor is not working proper. You can tap on the starter with a hammer sometimes to at least make the starter work. Make sure the truck wont run over you,but hold the key in the start position while tapping starter with a hammer. If the starter works ,then the starter needs to be replaced. If it doesnt work, then you will need to remove starter and have it tested before you replace it.. Let me know if that helps
Mar 27, 2011 | 2004 Chevrolet TrailBlazer
What special tool do you need to take a starter off of a 1996 polaris trailblazer 250 2 stroke?
to take the whole starter off you will need a three hole flywheel puller fro the right side and a drive cluth puller for the right side fix time is around 2.5 hours
Jun 29, 2010 | Polaris ATV
Starter on 2004 chevy trailblazer
If you can't get the key out of the ignition, it's probably the ignition switch (where the key goes in) that is bad, not the starter. The starter is on the right side under the exhaust manifold behind the right front wheel. It's not easy to change on those unless you know what you're doing.
May 30, 2010 | 2004 Chevrolet TrailBlazer
Need 3 point front seat, sensored seatbelts for '06 Trailblazer
for starters seatbelts do not have abs,you just need to get seatbelts that fit the anchorages so if chevy also make a trailblazer for another badge chances it will also fit(chevrolet in the uk sourced from korea)
Mar 20, 2010 | 2006 Chevrolet Trailblazer
No spark at plug on 99 polaris 250 trailblazer
i bought a 92 polaris trail blazer im very confused cus it has no battery and no battery leads going anywere and it has a back up pull start but its not geting any spark at all what should i do im not very good with quads?
Oct 07, 2009 | Polaris ATV
I have a 1993 Trailblazer 250 Polaris ATV, the starter works sometimes but has now stopped working. I am looking at replacing it but I would like some pictures of how it is done. I realize I could buy a...
before replacing did you check the battery,switch selenoid in order to make shure it is the starter that is the problem try hooking a battery direct to the starter it will isolate if it is a starter or not.
Sep 30, 2009 | Polaris ATV
Polaris Trail Boss ATV Logo
203 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
