Question about Pyle PLDN76DB Car Video Player
Hi i have a pyle pldn 7500 and my screen is locked its touchscreen
Pyle pclmdvr7 touchscreen unresponsive. how can i fix this problem?
Could be the main board / water damagen& corrosion / could need a replacement screen digitizer!
Look on ebay
Good luck
Lozza G
Dec 14, 2017 | Pyle Cell Phones
Pyle plcm 7500 car backup camera. Installed & was working but no2 but now screen black& keeps flashing view in back of camera..can't make it stop! Please help! was working until I touched a button.
I would only assume your connections to the wiring in the car are faulty, did you use solder joints and shrink wrap every connections you made? That is very important.
Nov 03, 2016 | Cameras
Pyle troubleshooting
Buy a cheap USB memory and stick it in the terminal to make it shut up.
Aug 19, 2014 | Pyle Pldnv695 6.95 Double-Din In-Dash...
When i turn on the car the radio doesnt go to the home page it goes to a screen with circle and arrows number 1234
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
Dec 06, 2013 | PYLE Audio PYLE PLDNV695 6.95 DOUBLE-DIN...
Help with seeing the video off my Pyle PLDN74BTI
bypass parking brake w/ no switch just codes for pyle pldn74bti car player
Jul 23, 2012 | Pyle PLDN74BTI Car Video Player
LOCKED TOUCHSCREEN...
PYLE PLDN76DB locked screen fix that worked on my unit. Hold in the reset button with small pin on front bottom right hand corner, for about 5 seconds and hold "ON" button on remote control at the same time. When unit reboots itself my screen started working.
Jul 03, 2011 | Pyle PLDN76DB Car Video Player
Pyle PLDN76DB Car Video Player Logo
234 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
