SOURCE: I received mail ... but dont send ... Because smtp problem
go to your settings to change what your phone is doing
SOURCE: I am having an HTC Touch HD T8282 Mobile . While
Go to 'Start > Settings > System tab > G-Sensor', and check how your browser is handled there, and adjust its settings, if needed.
Hope you are able to sort your problems out.
Cheers!
Carlos
Testimonial: "Excellent Feedback . It is working after a soft reset after Configuring the application for G sensor rotation . The Skyfire is working well. Thanks for the support"
SOURCE: I want to upgrade my
Try going to htc's support site, it would have the firmware there. But in some instances, it wouldn't be there, and if that's the case then chances are they haven't released such firmware.
SOURCE: I want to change the
You'll need to download a brand new rom for it. Your phone will run Windows Mobile 6.5 perfectly, so it's definitely time to upgrade. You'll need a computer running at least Windows XP, your USB data cable, as well as Windows Mobile Device Center installed to upgrade your rom. Once the software is installed, connect your phone to your USB, and start the .exe file for the rom. Make sure you have a full battery before upgrading your rom, and DO NOT TURN OFF YOUR PHONE even if it looks like it has locked or frozen - it hasn't. The file can be found here. http://www.htc.com/www/supportdownload.aspx?p_id=179&cat=2&dl_id=533 Input your serial number, and select the rom upgrade in the drop down box, make sure your phone is connected and charged, and that WMDC is running, and click the file to start the upgrade. Again, DO NOT TURN OFF YOUR PHONE even if it looks like it has locked or frozen. Leave your phone upgrading for a while, go have a cup of tea. When you get back, you'll have an upgraded operating system, and a phone with English as the language. Any problems or questions, please feel free to reply.
Testimonial: "Thanks a lot I have not yet tried it but will do so!! "
