Question about Humax Televison & Video
I HAVE A HUMAX MODEL LGB22DZT TV WHEN PLUGGED IN STANDBY POWER LIGHT GOES ON THEN OFF AND CONNECTION IS LOST CAN YOU HELP
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
Copy each of the following links into your browser address bar and watch all the videos.
You will have a pretty good understanding of what to do afterward.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
I only have one scart outlet on my tv my ariel is in the wall and mthen into my tv but its just picking up tv programmes on my humax recorder and not through my tv
The aerial should first go to the Humax, then from the Humax to the TV. Make sure power-saving is turned off on the Humax, otherwise it will not pass the aerial signal to the TV when the Humax is in standby.
If ypou want to use Humax power-saving, the aerial must be split so that one feed goes to the Humax and another to the TV.
May 19, 2016 | Humax Televison & Video
Singer TV Model 20LNC
while it goes off does it make a ticking sound?
Jun 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
What does code 576p indicate?
576p means 576 lines, progressive scan. 576 is number of visible lines on the UK system (and other nominally 625 line countries). The normal transmission system for these countries is 576i (interlaced scan), so I suspect that you are only seeing the 576p indication because there are no channels, and your TV is interpreting this as progressive scan.
The reason for no channels may be a poor signal from the aerial, or that the device (Humax or TV) has not been tuned. If you have power-saving enabled on the Humax, it will not pass on the aerial signal to the TV when the Humax is in standby. If this is the case, either turn power-saving off, or use a splitter to feed the aerial separately to the TV and Humax.
Oct 20, 2015 | Humax PVR9300T HD DVR
Why do I lose my recording schedule when I turn TV off? If TV is on Humax records perfectly.
Do you have a power strip or surge protector that recognizes when the power is disabled to the primary item, it automatically disables power to all other items? Easy way to check is to turn tv off and look for lights on other items plugged into surge protector.
Mar 02, 2015 | Humax Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
Its stuck on standbye
If it is a few years old, the most likely cause is failing PSU (Power Supply Unit) capacitors. These are replaceable by a competent electronics repairer.
For a more accurate answer, the model number would help.
Mar 15, 2014 | Humax Televison & Video
I wonder if you could please help me with a problem. I have just had Sky installed at my home and am trying to tune my TV into the signal on my Humax LGB22DZT TV. It just will not pick up the Sky signal. I...
I would advise connecting your sky box to the TV with a scart cable or better still a HDMI cable & not the RF cable. The reasons for this sre
1.. You should get a much better quality of picture from Sky
2.. You will not need to tune in the TV just go to the AV or HDMI input source to obtain the sky channels.
Jul 11, 2009 | Televison & Video
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Televison & Video Logo
264 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
