Question about BenQ PB6210 Multimedia Projector
Reset the lamp hrs. of pb6210 - BenQ PB6210 Multimedia Projector
  • 442 Answers
Press and hold the Exit button on the projector for 5 seconds to display the total used lamp time.
Press Auto on the projector or on the remote control to reset the lamp hour to "0".
Wait about 5 seconds to let the OSD disappear.
Posted on Mar 26, 2011
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I have a BenQ PB 6210. After switching it on, it first displays that the lamp has run 2001 hours and should be replaced. After this window disappears, it takes maybe 2 seconds and the projector shuts...
Hi cholthusen,
Please be informed that the average lifespan of a projector's lamp is around 2000 hours. The light bulb is almost certainly the problem. The best solution would be to change the bulb. The easiest way to do that is to change the lamp assembly (fresh bulb is in the new assembly). You may also try resetting the unit. Turn the unit off, then physically remove the power cord. wait for about 10-15 seconds then start it back again. If this did not work, please replace the lamp.
Hope it helps.
Thank you for using FixYa.
Jun 23, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
NEED DRIVER DOWNLOAD FOR BENQ PB6210 PROJECTOR THANKS
Hi, you can go to this webpage:
http://www.projectorcentral.com/BenQ-PB6210.htm
Youll notice it has the user manual which mentions which driver to use!.
kc
Feb 23, 2011 | Office Equipment & Supplies
How do I reset lamp hrs on benq 6210
Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
ii. Press Auto on the projector or on the remote control to
iii. Wait about 5 seconds to let the OSD disappear.
Feb 14, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
I have an HL- t50756 and it turns off every 10 minutes
Try to reset the lamp timer. To do this get the remote first shut off the TV. Then on the TV remote (not cable remote ect) press MUTE
then punch in the numbers 182 then POWER in that order, wait when the TV starts up the Factory meneu will appear go to Options press, then look for Lamp Hrs. to see how many hours you have on your lamp TV lamps last appox 2 years average use. 4,000 hrs. Try this, above where you see the hours go to reset or something like that and press to reset blub timer to zero. Your blub might still be ok, but the timer says times up and tries to shut off the TV thinking the blub is bad. By reseting the blub timer to zero the TV will think it's a new lamp. Until it really goes then no picture at all or gets very dark. Try this trick it might solve your problem.
Good Luck!
Oct 12, 2010 | Samsung DLP HL-P5663W 56" TV
Power is on and the fans are running, but green light keeps flashin
reset the lamp hrs and the filter hrs. if that doens't work replace the lamp.
Jun 02, 2010 | InFocus IN42 LCD Projector
Directions for lamp time reset
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jun 17, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Replaced Lamp and warning is still on screen
This work´d great
the "please replace the lamp" text disappeared but the lamp timer is still on the same, but i am still satisfied that the big red text on the screen is gone :P
/Newton from Sweden
Feb 29, 2008 | Sony VPL CS5 Multimedia Projector
My projector is shutting off after sometime by itself
Check the air filters and the Lamp unit.
Viren
Nov 26, 2007 | BenQ PB6210 Multimedia Projector
BenQ PB6210 Multimedia Projector Logo
124 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
