SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
SOURCE: setting clock
Setting the clock:
1. Press the set button 3 times until all of hte digits for the main clock are flashing.
2. Press the Skip Forward and Back button for the hour and the Volume Up and down for the minutes.
3. Press Set button once to confirm and exit the setting menul.
Call 866-387-2027 for manual
SOURCE: ipod nano 8gb instructions were not included. i
I would suggest you download itunes from the apple website (it is freely available) go to www.apple.com/itunes it allows you to synch your music libraries to the ipod. Also download the manual from the apple website you can get that at http://support.apple.com/manuals/#ipod
SOURCE: instruction manual for innova docking station
They do not exist. I was not given instructions with mine. Now its only function is an Ipod charger and speaker.
