Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
2 of the light bulbs blew out; replace them and less than a week later; they blew out again. Prior to this problem, the high setting would cause the fireplace to switch off. Ran it on lowest setting, it ran good till the bulbs started blowing out.
    President:
  • 3,074 Answers
I would check the sockets,make sure that they are burnt. I would also check the wiring for short/bare wire. Hope this helped Tim
Posted on Mar 25, 2011
  • zomba467 Aug 23, 2011
    Perhaps the fan motor is slowing down, which would cause more heat to build up in the unit, resulting in:
    1. Overheating at the highest setting, which triggers the emergency overheat cut off switch, and
    2. Might cause the bulbs to prematurely burn out.
    You might try replacing the motor, or cleaning it, or rebuilding it. Many electric motors have their brushes wear out, which can often be inexpensively replaced, or sometimes repositioned to take into account the increased wearing that has occurred with age.
Headlight keeps blowing
Check the amps that are being drawn by the headlights. Compare that with what the bulb should be drawing using:
amps= watts / volts
I am going to guess its higher but not to the point of blowing the fuse for your lights. I would then start checking grounds.
Or, you used halogen bulbs and you touched the glass. I doubt they would both fail at the same time from that.
May 11, 2013 | 1997 Toyota 4Runner
Could a bad ground be causing my turn signals and blower motor fuses to be burning out?
short in one of the bulb sockets for the backup lights is the most likely cause, water getting into the light is another. the only other thing i can think of is if there is a short in the neutral safety switch.
Oct 11, 2012 | 1997 Plymouth Voyager
One of my turn signals wont work, both my headlights only work on highbeams
replace the high beam switch which causes this problem. Also clean the terminals for the directional light bulb. That will cause a negative continuity to the bulb
Sep 01, 2012 | 1996 Mazda MX-5 Miata
I have a 1990 toyota camry, the fuse for the dashboard lights, glove box light & rear running lights(they are all the same fuse). blew, I replaced it and all was fine. A week later again the fuse...
Depending on the year. I.e. 89-91 camry, all have a yellow god fuse in the driver side of the trunk space behind liner.it is about 2''*3" cant miss it, being only yellow part. It is usual cause of certain outside lights completly out, have had to change mine 2 times in ten years, junkyard is best at 20$, new is near 200$.
Oct 15, 2010 | 1990 Toyota Camry
Kenmore 73089 AC keeps blowing the control board. (Doesn't respond or light up in any way when power button is pressed. Outlet power is good.) A repair tech replaced the board last summer. It blew again...
Sounds like a short in the wire. Not sure if that board powers off high or low voltage but I would say you definitely have a short. You need to replace the supply voltage wire.
May 14, 2017 | Kenmore 73089 Air Conditioner
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lights ou at the rear of my 88 s10 checked fuses none blown
a local surge coula blown your bulbs. check any fuses and check you tailight bulbs.
May 11, 2009 | 1988 Chevrolet S-10
1991 toyota corolla tail lights
The tail lights in my sister's '90s Subaru had a similar problem, and nobody could diagnose it, so she just kept a bunch of fuses in the car. (When she replaced a fuse, it would be a while before it blew again -- days, weeks or even months).
In your case, there's a continuous short circuit somewhere. I'd start with the tail lights themselves -- remove the bulb on one side, replace the fuse, then test. If the other bulb lights and the fuse didn't blow, you know the problem is in the wiring to the bulb you removed. If the fuse DID blow, replace the bulb, remove the bulb from the other light, replace the fuse and test again. Examine the wires carefully looking for nicks or bare insulation.
If the fuse fails whichever bulb is installed (or even if no bulbs!), then the short circuit is probably at the fuse box connectors for those wires, or inside the fuse box itself.
I assume you're talking about the tail lights that turn on and off with the headlights. If you're talking about the brake lights, the test procedure is the same, but don't forget about the high-mounted center brake light, if your car has one.
Oct 16, 2017 | 1991 Toyota Corolla
Volvo xc 90 2004
sorry havent got the answer but mine done this whn the lights worked fine then week later bulb blew (smashed)
Jul 19, 2008 | 2003 Volvo XC90
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Heating & Cooling Logo
87 people viewed this question
Top ACE Heating & Cooling Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Tim Whalen
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
