Question about GE PSS26SGRSS Stainless Steel Side by Side Refrigerator
The circuit board seems to be bad. I'm very handy but not sure if this is something i should change myself? To me the hardest part was figuring out how to not break the plastic tips holding the board in place.
    President:
  • 2,468 Answers
All you need do is carefully take a needle nose pliers and carefully depress the locking tabs on the outer side of the board while applying a small amount of pressure outward on the backside of the circuit board till it lets you get by these tabs,then just remove all harnesses and replace board,tabs will automatically snap out when board is pushed onto the plastic tabs
Posted on Mar 25, 2011
Clean mode temperatures remain on
Self cleaning mode would lock the oven door. Sounds like the control board is bad.
Feb 17, 2014 | GE JBP71 Electric Kitchen Range
Replace control board
You should be able to change a board I did on our samsung one . For that it was just unscrewing the board the disconnecting std connectors and reversing the process with the new board
http://www.appliancepartspros.com/search.aspx?model=wm2650hwa&page=5 $152 for a board
i would assume that most machines are designed for quick simple build so everything is moduler
Jan 09, 2014 | LG Washing Machines
The picture on an older 31 inch tube tv will go to a line randomly and if ya give it a slap it comes back. I did buy a new tv but I figured i would try to fix it myself. I do work with furnaces for a...
Your TV may need some soldering around the deflection circuit. It is too dangerous, to work on a 31" CRT TV due to its high voltage which, can kill you!. There is about 35,000 volts or more around, the deflection board and the tube. You need to resolder the components in the deflection board and you've got to have the right soldering iron and some soldering experience.
Good luck and be very careful
Sabre
Feb 22, 2010 | Sanyo Televison & Video
I have a JVC av36150 36" when you first turn TV on..there is no sound.. You have to tap the front of it..or go around back and tap the audio input board. what could be the problem..TV works fine once its...
Hi
You seem to have bad solder joints.
If you are handy with a soldering iron you can take off the back cover and knock around the circuit(using something non conductive , i.e a wooden salad spoon) to locate the area of the problem.
Start by following the speakers wires to the connector(s) on the circuit board and the audio output i.c should be near by and mounted on a heathsink, thats the general area where you might find bad solders, you may have to do a bunch of them before you get to it as they are not allways apparent.
Hope this will help good luck
Dec 13, 2009 | JVC AV-36150 36" TV
My 4-wheeler seems to not catch any fire..
get a screwdriver and find your cylinoid. there are two bolts coming out the top. touch both bolts w/ the screwdriver and the key on. it should crank your for wheeler. this is just the way us country boys do it.
Mar 08, 2009 | Sport & Outdoor - Others
Gauges not working..
Check your fuse box for lose wiring in the back and, check the fuses as well. if the problem still persist, then, check the cables on the back that run to the actual motor. these cables may have been severed due to age.
Feb 09, 2009 | 1996 Jeep Cherokee Country
Problems with Nikon Telephoto AF-S Nikkor 600mm f/4D ED-IF I Autofocus Lens - Black?
It sounds like the circuit board in the lens is intermittant or there is a bad connector contact internaly where the circuit board connects to the harnesses.
Trying to find a cold solder connection on a multi-layer circuit board with SMD technology componts is not usually very feasible and reliable.
A major cause of this type of failure is from humidity, and or banging or dropping the lens unit.
I would start by changing the circuit board and the connector assembly inside the lens. This is an expensive fix, but it is effective.
If you request the described repair and offer to pay the cost, I am sure they will do it.
Jerry G.
Apr 29, 2008 | Nikon Telephoto AF-S Nikkor 600mm f/4D...
Convergence?
From what i see in these posts most say its the IC ship to replace i will get one for my 46807 also but dont know where yet .
also i seen that if that dont fix it then there is a few resistor's to resolder someplace dont know where either..but i can make the repairs myself im handy CROSS fingers ..:)
Nov 24, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Cost to replace LCD screen?
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
Aug 02, 2006 | Canon PowerShot SD500 / IXUS 700 Digital...
GE PSS26SGRSS Stainless Steel Side by Side Refrigerator Logo
103 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
