Question about Dishwashers
Dishlex Prestige 150HD not working at all. Previously my daughter hit door and stopped. at times dishwasher would stop, then once depress door it would start up again. At present nothing works.
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
SOURCE: Dishlex Global 300 - stopping mid cycle
This is just a suggestion....  so please try and please post any corrections.
Anthony M is on the right track.  Refer to his entry and download the manuals. Tks Anthony.  When the Dishlex 300 starts for the first time, there is a service mode set up. The service mode allows you to set a 'fill-time' for the water to reach the right level, dependent on the water pressure and flow... which is described in the manual.  So resetting the Dishlex is the first step. Then set the water level.  If the water is too low, it will not wash, it will flash. When the water is too high, it will leak out of the rubber seal.
I hope this helps you all. Waz
Posted on Jan 14, 2009
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Dishwasher stops part way through cycle
Sorry I have taken along time to reply but I lost my email access for awhile.Now the fault with your dishwasher is its taking too long to drain.Please reply if you still require help.Once again sorry for not getting back to you sooner.
May 27, 2010 | Dishwashers
My dishlex dishwasher 160 series has stopped
Have you disconnected the drain, fresh water, power and the 2 to 3 mounting bolts to the counter?
Mar 07, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Apr 11, 2009 | Dishwashers
Dishlex Global 450 flashes ''oF'' - Continues to drain
I also had the oF error message just today, tilted the dishwasher back 45degrees and message dissappeared and all sweet as now. Put old towel under legs to catch overflow Thanks to david
Dec 29, 2008 | Dishwashers
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
