Question about ViewSonic VA1912w 19" LCD Monitor
Sir, im using veiwsonic lcd monitor when iam starting my system my lcs is blinking for 3 - 4 time and not dispalying ... but the green light is blowing .....
  • 11,361 Answers
It does the same when attached to another PC, and all the cables are good?
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 25, 2011
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
Veiwsonic VA1912WB flashes then goes blank
You have a very common problem that happens to many LCD monitors after 2-3 years of use. Your monitor has blown the power supply that controls the backlight bulbs. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures of what blown capacitors look like. Open the back of your monitor and replace any of the parts that look like the ones in the pictures and you should be back going again. Be sure to usehigh temp (105c) replacements. Resolder them in with the side polarity stripe going the same direction and the old one came out. The values of the bad parts will be marked on the sides of the ones you take out, they can be ordered online from us or several other places, the one from Radio Shack are not suitable for use in the high heat inside on the monitor and will soon blow again.
I hope this helps, if so please rate my solution.
If you have more questions just ask.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | ViewSonic VA1912WB 19" WideScreen Monitor
Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Jul 24, 2009 | Samsung 226BW Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Diplay Optimization drivers
hello sir,, most commonly you dont need to install the monitor drivers the system assignes one automatically,but sometimes to get the full features of the monitor u might need one., see if the model no. is present in the drivers database,?? what if u assign it as :plug N play" monitor, also sometimes the nearby models are compatable, try this and let me know..
Jan 10, 2008 | Compaq Armada M700 Notebook
Veiwsonic 924x
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Dec 27, 2007 | ViewSonic VX924 19" LCD Monitor
Power blinks green on lcd 17" veiwsonic
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Lcd 17" veiwsonic power problem
17" lcd veiw sonic power blinks
ViewSonic VA1912w 19" LCD Monitor Logo
54 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
