Question about Refrigerators
Hi I have a upright 'Proline' freeze which seams to be running all the time and during the last few days the temp gage has moved in to the green area. I turned on the rapid freeze light and it has taken two days to move to just into the yellow. Also the side of the freezer (about 500mm from the base close to the door) is quite warm/hot to touch. Any ideas? Steve
  • 132 Answers
The fridge has lost it's refrigerant charge. The leak needs to be found and repared before new gas can be added.
A tecnician can help you with that
Posted on Mar 25, 2011
Radiator Leaked No Light on Dash boad about it
check the radiator censor making sure that the wires for this have not come off is there any fluid on the road when its been left for a few hours normally a car loses water any way may be half a pint a month or so this is normall check hoses for splits before forking out for a new water pump
Aug 24, 2012 | 2002 Kia Spectra
My "check gage" light on
sounds more like maybe bad temp sensor
May 20, 2011 | 2006 Chevrolet Express
Hi, My unit is gas, and is just a couple of years old, it will not kick on unless I turn it off then turn it back on, I have TWO green lights that STAY on, then a yellow light blinks, and blinks again 4-5...
check flame sencor is clean , check connection from sencor to the board , or pressure switch could not be working try jumping this out andf seeif it fires up check filters are clean
Jan 20, 2011 | Heating & Cooling
I have a Proline High Rate Sand Filter that i purchased at NAMCO. During the last few days, when I turn the filter on, I get a water leak in the area where the top unit of the filter is connected to...
I have a Proline High Rate Sand Filter I purchased at Namco.I only had it a year, now it have a leak coming from underneath it.What can I do to stop it ?
Jul 28, 2010 | Garden
Hi, there is a Ductless LG Model # LA180CP that has freez up problem. Sometimes it freez up after 3 days working and some times after couple of hours working. Freez up start from indoor unit. Average of...
what refig and where are the pressures. freeze up is always low charge or lack of air flow and always occurs at the evap. Once it starts and you loose surface area you have to defrost manually
Aug 09, 2009 | Heating & Cooling
LG Split Ac-Sprinkles water in roomafter a while of cooling
first check to make sure that the indoor unit is very slightly off level sloped to the drain area also turn off power and inspect the indoor coil with a flash light to make sure all the fin area is open the drain pan has two possible drain connections if they are both hooked up then the primary "lowest"
could be stoped up a blast of water or air to the drain line should clear out slime also make sure their is a trap in the drain line or the water will only drain dwhen unit is off hope this solves your problem thanks
May 15, 2009 | Heating & Cooling
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Lasting plastic smell
Obviously, this should not be! First, we need to know if the coffee maker is working correctly. If you have a candy/oven thermometer, check the output temp of the water. Be careful...it will be hot! The correct temp should be about 180-185 degrees. If it is hotter than that...return the machine. It has a defective thermostat.
What you can do about the taste: try taking some baking soda and mix it with the feed water. Use about 2 tablespoons in at least two cups of water. Then, add plain water. The baking soda can't hurt you but throw it away and clean the pot. Now, take some water and run it through. If the taste is gone...enjoy! If not, try another unit.
Nov 20, 2007 | KitchenAid Pro Line Coffeemaker Coffee...
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
