Question about Candy Dishwashers
I have a candy cdi 1022 built in dishwasher, is the door ment to stay open, for loading dishes as the door keeps closeing on its own
  • 209 Answers
SOURCE: Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Posted on Oct 07, 2007
  • 146 Answers
SOURCE: GE Built in Dishwasher
You possibly have several problems. The plunger is broken to the dispenser. You will have to disassemble the door to check the dispenser. Your water not draining is why the dishes aren't getting clean. Check to see if your drain hose is clogged. It may drain at a disposal or through a siphon gap which is mounted to the rear of your sink. Sometimes the siphon gap gets clogged and will cause drainage problems. It sometimes is located at the right or left rear of the sink and has a cap that sits about 3 to 5 inches high. Take the cap off and make sure there is no clog.
Posted on Dec 29, 2007
  • 21 Answers
SOURCE: KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Posted on Apr 09, 2009
SOURCE: Maytag Quiet Series 100, Model # MDB5600AWS, built
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Posted on Jan 04, 2010
SOURCE: Candy CDI 45 E4 code
I have E1 code on Candy dishwasher CDI 45
Posted on Sep 29, 2010
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
The dishwasher door keeps popping open mid cycle and door will usually not close or stay closed. it takes 4 hours of me hitting continue and holding the door closed to get it to finish a load
The catch on the door latch assambly is weak and the latch needs to be replaced, this vidoe will show you how to replace the latch,the part# is 8183830 it could be purchased at your local appliance parts store or online at,searspartsdirect.com assuredaprts.com apdepot.com
repairclinic.com appliancepartspros.com
Aug 08, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
ADJUST TENSION DOOR
Just below dish loading door there is a panel. Remove screws (if applicable) to find tension adjustment. Turn screw to the left to loosen or opposite lifting door open or closed untill happy with tension. Some washers have no adjustment, I suggest opening door fully and pulling out bottom load tray, loading and then top tray or rack, pushing top in first then bottom rack. Use a glass fry pan cover or fry pan for weight on door while filling soap. Good luck, best regards
Jan 31, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
Nov 23, 2010 | Candy DFI Plan Built-In Dishwasher
Our newer dishwasher does not clean the dishes presently. The water heats up, and drains properly, but I noticed the sprayer nozzles are not spinning when I open the dishwasher.
Try manually rotating the spray arm. Check the orifices & clean if clogged.
After loading the dishes check every time before closing the door for free rotation of the spray arm.
Apr 01, 2010 | KitchenAid Architect? II U SERIES KUDS03ST...
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Dishwashers Logo
165 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
