Question about Bodum GRANOS (3020-16US) Espresso Machine
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Posted on Apr 14, 2011
Delonghi repairs sydney
Hello -
This is the link to the Delonghi Australia web page you can use to find a nearby repair center :
http://www.delonghi.com/en-au/customer-support/service-locator
Best wishes.
Feb 13, 2018 | Bodum Coffee Makers & Espresso Machines
The water stopped coming out of the group head so I took the damn ting apart. Espresso parts everywhere... I can't figure out how the water flows through the boiler then on to the group head. Any advice...
Hi
It was probably your 3 way valve. Its located behind the panel below the group head. 2 screws and it slides to the right only. Remove the black nozzel then the #14 nut on the bottom of the 3 way. Solenoid will slide off. There are 2 screws holding the 3 way on. Install the new 3 way in rreverse. and you will be good to go.
Dec 30, 2010 | Rancilio Silvia Espresso Machine
Hi, no water through e61 group head ?
Check the metering jets and filter on the top of the group heads.
Jul 15, 2010 | Coffee Makers & Espresso Machines
How do I replace the group gasket?
1. empty the water tank
2. turn machine upside down
3. remove shower rose(one screw in middle)
4. remove group head (two hex screws)
5. pry out old gasket
6. fit new gasket and reassemlbe
Dec 25, 2009 | Gaggia Classic Espresso Machine
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
Parts for the Bodum Granos Espresso Machine
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Feb 21, 2009 | Bodum Granos 3020-16 Espresso Machine
Bodum granos new will not function
the connections to the heating coil element looks faulty.check it.
Jan 18, 2009 | Bodum Granos 3020-16 Espresso Machine
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email gethudall@hotmail.com
Feb 18, 2008 | Bodum Granos 3020-16 Espresso Machine
This is not a fix but it may be a way to at least get an espresso without milk. I opened the panel on the back and removed the to wires at the top of the circut panel. They are both fixed to a plug so all you have to do is gently pull. This turned of the steam/water function and the the water came through the head as it is suppose to. I did not get all the parts with mine so if anyone tries this please post the outcome. Remember to unplug the machine before you open the back. I will post the real fix if I figure it out.
Oct 26, 2007 | Bodum Granos 3020-16 Espresso Machine
Bodum GRANOS (3020-16US) Espresso Machine Logo
177 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
