Model reu2402w need jets for lpg the unit at the moment is natural gas still going but need to run it on lpg
    Brigadier General:
  • 4,736 Answers
Who is the manufacturer of your heater? Unfortunately, the model number alone doesn't help much. Also, you said you need the "jets" to convert it to LPG. Did you mean you needed the burner Orifices?
Please advise. Thanks
Posted on Mar 25, 2011
Is model no. GFC101W0 propane or natural gas
the difference between natural and lpg is the jet size and it would not be cost effective to produce specific models when all that is required is a change of jets
there may be a stick on tag on the back which states it if is lpg or natural gas but I suggest that because it is gas that you have a gas fitter come in and inspect it
Oct 14, 2015 | Kitchen Ranges
Need to convert Paloma gas heater from natural gas to lpg in qld.
You can't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Among other things besides having to reprogram modulation, you'd also need to re-jet it and that's not possible in the field. NG and LPG jets are not the same due to vastly different operating pressures.
Some brands can be field converted but not Paloma/Rheem/Richmond/Rudd Tankless units!
May 18, 2014 | Water Heaters
Hello Everyone, I have a Totum Patio heather the Natural Gas models. I now have to move to a condo with no natural gas access. Can I convert this Natural Gas model with the LPG models that uses Liquid...
It can be done but you will need a professional gas fitter to do the job. It will need different jet sizing and the air mixture tube adjusted to compensate for the different jets.
Oct 27, 2013 | Barbeques Galore Totum Hls 35,000 Btu...
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
Imperial ifs 40: gas comes out of jet and the burners work fine for a moment, then the flame ignites inside the burner and makes a worbling noise every now and then popping. is this low gas...
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
Mar 21, 2011 | Imperial IFS40 Deep Fryer
Hi im a plumber/gas fitter who has been asked if i can convert a wildcat 410 (a2) ser 1983 from lpg to ng which is currently in use at a crash repair spray booth is this possible?
Yes look up the gas valve part # and find the LP kit for that model number. It will come with new pilot orifice, new burner orifices and the springs to replace inside the gas valve. Remember that natural gas is .08"wc and LP is a heavier gas it needs to be set at 11"wc .You need a manometer to check the pressure before you light it again .Did you know that propane provides more energy per unit volume than natural gas. Heat is measured in BTUs, or British Thermal Units. Propane provides about 2500 BTUs for the same volume of natural gas that only gives 1000 BTUs.
Nov 22, 2010 | Heating & Cooling
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
What are the conversion rates from gas to lpg for our Prima LPR851 Hob? so we can fit our kit
wat gas?natural to LPG call the service center of the unit to buy an injectors nozzle want u want(LPG to natural or Natural to LPG)tell the model of ur unit.
Sep 08, 2009 | Cooktops
Stoves 1000DF Richmond - LPG Conversion
the back decal will be the original manufacturer and the person doing the conversion would have fitted the LPG decal on the front as a warning to gas fitters carrying ot repairs
The only difference is jet sizes and air shroud positions
I would suggest that you have it inspected by a gas fitter to ensure that the flame is the correct color indicated by the correct jet and shroud position
it should be a royal blue
if a yellow it is wrong jets for the gas
Oct 11, 2017 | Stoves 1000DFDLm Gas Kitchen Range
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
