Wi fi not working error 10 - Computers & Internet
    Novelist:
  • 142 Answers
Code ten means there was some kind of hardware error that prevents windows from loading the driver.
If it is a USB Wireless device, make sure you are not using a hub. Plug it into a full power USB port.
Try a different port. If it is a built in card, such as PCI or MPCI-E, you will likely need to replace the device. Sometimes you can get a code ten from lack of resources. Try dissabling some hardware you do not need in the device manager. Items such as serial ports etc. (Anything you don't use)
Posted on Mar 25, 2011
Unable to get internet
You can separate the troubleshooting into parts. Go to a place having a wi-fi internet hot-spot, like Starbucks or Gloria Jeans'. Assuming you are in the USA:
http://www.wififreespot.com/
Get a coffee and turn your tablet wi-fi on. From
http://www.manualslib.com/manual/742236/Rca-Rct6272w23.html?page=11#manual
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it. Tap 'Agree to conditions' if necessary.
You should then be able to go to a webpage. Once you get this bit working, you can turn to your home internet.
You need of course an account with an ISP, who will probably supply you with a gateway (modem/router). If you only have a modem (connection box to the ISP) that does not have a wi-fi capability, you will need to get a router (wi-fi broadcaster). These can be quite small and neat.
http://phandroid.s3.amazonaws.com/wp-content/uploads/2015/10/OnHub-by-ASUS-Screen-Shot-2015-10-27-at-5.29.02-PM.png
For assistance on this contact your ISP tech help line, since some of the advice is peculiar to the equipment they use.
Connect the router (if you needed to get one) to the modem with an ethernet cable
http://cdn2.pcadvisor.co.uk/cmsdata/features/3502678/ethernet-cable.jpg
and follow the setup instructions that came with it. Then do the same as in the cafe wi-fi hot spot. It should work.
Mar 03, 2016 | RCA 8" Android Tablet w/Dual Tuner
How do I get the wi-fi- working on my laptop after installing windows 10?
try typing wifi or wlan in the search box or windows wireless, that may throw up results for you to trawl through
Oct 26, 2015 | HP Pavillion G6 1d72nr I3-2350m 15.6"...
How to save wi fi password on Apple Iphone5
Try this. Go to Settings Wi-Fi, click on your home network and then the little I (information icon), make sure HTTP Proxy is switched to off. click forget this network. Reboot phone (power off, count to 10 and power back up).
Go back to Settings, Wi-Fi, Home Network and try again. If that doesn't work, click Renew Lease.
Sep 29, 2015 | Apple Cell Phones
Wi Fi Problem
Sounds like a bad ios or may be ios get corrupted try to restore the ios file.
Feb 15, 2014 | Apple iPad with Retina Display 4th...
Dynex blu-ray wi-fi disconnects after 1 hour
The issue is with the chip that works with the wi fi. It is erratic in operation. Too expensive to fix. Can you just hook it up via ethernet cable for internet connection?
Sep 07, 2017 | Dynex™ Televison & Video
My wi.fi not working
Did you turn the wireless switch on which is on the side or at the front of the laptop?
May 07, 2012 | Dell Inspiron Mini 10 Notebook
The nintendo wi-fi doesnt work it says error 51100 but my wi-fi password is correct what do i do?
Welcome to Fixya. Please follow the instruction on the link below to fix the error
Error 51100 Fix
Thanks
Aug 31, 2011 | Nintendo DS Lite
Xv6700 phone won't make calls "a wireless radio must be attached"
I HAVE THE OPPOSITE PROBLEM, I WANT WI FI TO WORK WITH OUT PHONE SERVICE ACTIVATED. IS THIS POSSIBLE?????
Jul 23, 2010 | Audiovox XV6700
I have a gate way laptop with Intel® PRO/Wireless 802.11g integrated wireless 10/100/1000 Mbps integrated Ethernet LAN card, i cannot connect to my wi-fi network, is it possible that the wi-fi card is...
Wi-Fi card can be considered broken only if its not able to scan for any available networks. Also, do check in the device manager of the computer. Check for the device status of this wireless adapter there. If its properly installed, etc., it should say, "This device is working properly". There is also a fix for other error messages. Regarding hardware breakage, we cannot come to a conclusion so easily as we have all these things to check. The case may be little complicated as its an in-built wireless card. We cannot even remove it and try on a different computer.
Mar 17, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Computers & Internet Logo
David Payne
David Payne
