Question about Miele K9757ID1 (10.4 cu. ft.) Refrigerator
My Miele K9757ID has begun to make a really loud hum when the motor is working. (as you know this kicks in at regular intervals.) It used to be really quiet, and now it is really noisy. It is only 15 months old. has something gone wrong or is this common? As it is in an open plan kitchen living area I chose this model for its quietness and was really pleased with it to start with, but this noise is now driving me crazy! Can you help please? Thank you. Deirdre
  • deirdremoyla Mar 25, 2011
    I have now defrosted the freezer part - and hey presto - the problem has disappeared! My lovely quiet fridge/freezer is back. Thanks for your help. Deirdre
  • 132 Answers
Well i am sad to say that a problem is developing.
The compressor is starting to get tight in it's moving parts. This will continue to get worse until the compressor fails all together. If you measure the amp draw and compare this to the rating label you will see the amps are going up slightly.
Firstly check that the condenser is clean and there is plenty of air flow. If that is ok then you will need a technician to help you
Posted on Mar 25, 2011
Thermostate kicks pump motor on ok. but when its time for the fan motor, all you here is a loud humming then the breaker blows
check for a failed start/run capacitor for the motor
if the motor spins freely then the humming will be a frequency hum because there is not enough power to start the fan running
the extra current will blow a cb
Apr 08, 2016 | Mastercool 67680 Evaporative Cooler Air...
No fan and short time heat, did something get knocked loose in transition?
Power control is accomplished by turning magnetron on and off at different intervals. Check when cooking if power is coming on and going off at regular intervals. Time these intervals and see if they are random or regular.
Mar 21, 2017 | Whirlpool WMH1162XV Microwave Oven
When I turn it on, it starts to hum but after 30 seconds the red light flashes and the intake/drain light is on. The Miele tech support says to take of the kick plate and empty check for a clog. Any...
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Perhaps Miele could send you one of those tools so you could try and see it the pump seal has swelled up and stuck.
Gene
Aug 12, 2011 | Miele Incognito G858SCVi Built-in...
Have a Miele G1022i dishwasher (built in). It makes a humming noise when the power supply is turned on. All the indicator lights flash. Have tried cleaning out the drain and removed water from the salt...
Gene
Aug 05, 2011 | Dishwashers
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
The motor on my 2002 Deville has begun to hum.
Could possibly be the power steering fluid is low. This will make a humming noise and if it gets louder it could mean that the pump is really low. It is hard to diagnose these types of problems without actually hearing the vehicle run but maybe this will give you a starting point. Sincerely, Roger
Feb 07, 2010 | Cadillac DeVille Cars & Trucks
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Really loud humming noise and freezer is defrosting/refreezing
Connect only to an outlet, do not use an extension cord. If you really must use an extension, make sure it is capable of handling the load. Should be a 16ga minimum, 14ga preferred and not exceed 25 feet. If you are having this issue while plugged directly into an outlet, perhaps the circuit is weak, and you should try another outlet.
Other possibilities include: a short-cycling thermostat. This is when the thermostat tries to kick the compressor back on too soon after the last running. OR Your compressor is on the way out. Sometimes the installation of a "Hard Start Kit" will aid a failing or stubborn compressor. If you've eliminated all else, consult an appliance servicer to buy the hard start kit. They typically are a universal fit, and come with instructions.
Jul 06, 2009 | Amana ASD2626HE Side by Side Refrigerator
Dishwasher pump starts washing cycle then stops and just hums loudly.
It's humming loudly because something is caught inside it. You can take the kick plate off and start to turn it with a screwdriver to try to get it jump started. Sometimes this will fix the problem because it can cause the blockage to be moved through the system. If this doesn't work, you'll have to change the motor (and this is a pain) or buy a new dishwasher.
Jul 03, 2009 | Kenmore Dishwashers
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
Miele K9757ID1 (10.4 cu. ft.) Refrigerator Logo
549 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
