Question about Toca TDBG12 Djembe
I want to send the 15 pieces of musical instruments ''Djembe ''by surface/road. the distance will 2000km. they are 10'', 11'' & 12'' @ 5 pcs eac & total 15 i want to know how i can pack them.whic material should i haveto use?
    Master:
  • 344 Answers
In a sturdy box lined with some good foam for shock absorbing, i would surely use several layers of varying density. http://www.closedcellfoams.com/ has some really good materials for packaging things like this. Contact them for estimates and such.
Posted on Mar 25, 2011
I have a Crate V16 -15 watt Amp w/12"-16 ohm speaker. Can I use a 8ohm speaker instead ?? Thanks
According to the manual, it needs a 16 ohm minimum load, so no, you best not use an 8 ohm speaker.
Nov 13, 2014 | Music
Connecting to garageband
Only newer models with class-compliant USB (made last 12 months) can connect to MACs - & IPADs and PCs.
Older models require drivers available only for Windows.
Mar 13, 2014 | Casio Celviano AP-220 Digital Piano...
Hi you you there money money money???????????? got none
I just heard back from orange. Here is the body of the response.
Hi Vito,
Thanks for your inquiry, but I'm not sure what amp is to which you are referring. To my knowledge Orange has never produced a "Sundown Rover 15 Watt." If it is a vintage amp, we wouldn't have a schematic for it regardless unfortunately.
Perhaps you could give me a little more info on it or snap a picture and send it in an email?
Cheers,
Alex
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 15, 2011 | Orange Amps Orange Sundown Rover 15 Watt...
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
May 04, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
I have a midas venice 320 mixer, there is no output on the four auxlilary sends, but i have an output on other outputs and headphones.
You must have aux sends on each individual channel and each AUX MASTER turned up for output and each of those outputs must be going to separate amps.
Apr 12, 2011 | Road Ready Mixer Case for Midas Venice 320...
I just got this bass and am getting speaker pop at low frequencies, any ideas of what is causing this? All other frequencies sound great.
If you are driving the speaker too hard it will pop. This caused when the voice coil is driven mostly beyond the pole pieces of the magnet. Without the magnetic field the back EMF of the voice coil drops off and the current shoots up. The voice coil can't move farther so there is a discontinuity of movement which causes a pop.
200 watts is a lot to put into a 12 inch speaker so you have to be careful to not drive low frequencies at excessive volume. It is both very hard on the amp and doesn't do the speaker any good either.
If you want loud lows, you should get a subwoofer of at least 15 inch speaker to handle the lows.
Aug 04, 2010 | SWR Workingpro 12 200watt 1x12" Bass Combo...
I need to know the ohm rating for the speaker in a
Judging from the "10D", that most likely means 10 watts. 6.5 inch speaker, probably 8 ohms. Most amps of this nature have 8-Ohm speakers.
Their 12-watt and 15 watt amp have a 6.5". Their 20 watt amp has an 8". The 80 watt has a 12".
Hope this helps.
Mar 28, 2010 | Peavey Pv 2600 Power Amplifier
Amp goes quiet after working fine for about 15-20 min.
If you are not a tech, I suggest you send it to one. If you are, after signal-dropout spray output transistors (one at a time) with component cooler (freeze spray). If still no results, go to the other transistors & IC's. Chances are that will pinpoint faulty component.
Apr 05, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Toca TDBG12 Djembe Logo
35 people viewed this question
Top Toca Music Experts
Michial Gueffroy
Are you a Toca Music Expert? Answer questions, earn points and help others
