Question about Canon PIXMA iP4600 Color InkJet Photo Printer
What is the best cleaning chemical to clean the print head of a canon ip4600? I bought acetone but it does not get the ink off my fingers so I am thinking not the right cleaning chemical. The large black cartridge does not work. I use to use 3rd part cartridges and it did stop working then then but I bought an original canon and it still does not work.
  • Canon Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Mar 25, 2011
I have a Pixma iP4600. Colour printing is coming out very orange (i.e. I guess no blue). I haved replaced the cyan cartridge but the nozzle check shows not cyan being printed. Any help would be...
if you havent printed in a while the printer heads might need cleaning to free up the ink flow. try running a head clean at least 6 or so times to make sure it works properly
Feb 25, 2010 | Canon Office Equipment & Supplies
Hello there, i have a canon MP370 which i have been very happy with and had no problems,however the machine when it prints now all the colours are very faded and banding occurs right accross...
Check your cartridge first and take a look if it is not running out of ink,try replacing it with a new one then on your printer maintenance do head cleaning,then print nozzle check to see which color has a problem,if it doesn't change try to look for chemical solution that are being use to clean print head. soak the print head,dont touch the head with your bare hands or anything hard its sensitive.
Sep 12, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Canon Pixma iP4600 not printing cyan
I had the same problem and I finally FIXED IT. I first tried replacing cartridges - no good, I then took the print head out, dismantled it and washed every component, no good. I then noticed that there were small streaks of blue on the paper when I tried to print a blue image so I worked out that the blue ink is getting through, but very slowly (yours might not be getting through at all but don?t worry this should still fix it). So I got a very thin pin and pushed it into the cyan pad on the print head creating a thin channel for the ink. Tried to print again, perfect, blue now working. Hope this helps - remember, you do this AT YOUR OWN RISK, there is no guarantee this will work for you, it worked for me but there is the obvious risks that you may break your printer. I did it because it was broken as far as I was concerned and I had nothing to lose if it broke completely, you must make that choice yoursel
Aug 25, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Ink not working
Assuming that all your cartridges are clean. Then the next step is remove your print head and clean it. If you haven't done this before, it is very easy. First printer's remove your cartridges and life the lever on the upper right hand side of the print head. If you have done this, skip the next paragraph.
Gently remove the print head and put it in a container, and fill it with hot water. I usualy empty the contents of a small bottle of ink jet cartridge cleaner into the tub as well. You should see the ink literally seep out of your print head. It's best to leave it for a few hours, but if you can't wait, leave it for several minutes, and gently press a folded paper towel against the print head base. It should make a clean impression. Dry it and put it back in your printer. Test print.
If your inks are clean, and you have cleaned the head. It's unlikely, but there is an outside chance that the contacts at the back of the print head carriage could be dirty. Gently clean them with a cotton bud dipped in ink jet cleaning fluid.
If it still dosen't work, then it looks likely that your print head is damaged and will need to be replaced. You can buy replacement print heads on the internet for about £50 pounds. (UK)
However, with the price of printers falling, it might be better to cut your losses and buy a new printer. I would pay a bit more and go for the Canon IP4600 which is the nearest replacement model to the IP3000. It also has separate ink tanks and significantly a removable print head. The down side is that the inks are chipped, so if you plan to refill them, you will need to plan to buy a Canon cartridge ink resetter to keep your printer happy. (About £20)
Hope it helps.
Aug 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Waste absorber full
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 19, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
CANON S400 PRINTING PROBLEM
What printer do you have? Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Nov 02, 2008 | Canon S400 InkJet Printer
Canon S530D-Have cleaned nozzles,changed ink tanks ,no printing of any sort
HI,
No I haven't fix the problem. However I've been doing all the cleaning,cleaning and more cleaning. I finally gave myself a x'mas present. I bought a new printhead for the S530D. It's working perfectly now. I was tossing whether to get a new IP4600 or a new head, finally decided on the latter. Simply I can't get after market cartridges for the IP4600. The cartridges for the IP were way too expensive at this moment and not knowing whether the claims for the print numbers are accurate. Perhaps readers may be able to collaborate the claims for the IP4600 or IP4500.
Regards and seasons greetings & a happy new year 2009,
yuen yoon
Aug 11, 2008 | Canon Office Equipment & Supplies
Print head for canon ip90
There is a very easy fix for a Canon IP90 not printing either color or black. I just fixed mine a few minutes ago. Go to the local Dollar store and buy some nail polish remover. Then open up the printer, remove the ink cartridge(s) and put a few drops of nail polish remover in the hole that receives the ink. Works like a charm and fixed mine in just minutes. After inserting the polish remover (actually just Acetone with some glycerin) reinsert the ink cartridge and do a deep clean using the Canon utility from the Control Panel under "Printers > Properties > Maintenance (right click on the Printer icon in Control Panel to start)." You can also simply use acetone. Another trick is to remove the print head which holds the ink cartridges (although I could not figure out how to do this but it's doable) then put a paper towel soaked with distilled water (tap water probably OK) in the microwave, heat the towel and quickly put the print head on the hot paper towel. As a last resort simply order a new print head from the Internet and replace the print head. I would presume it would come with instructions for removing the old print head.
Dec 29, 2007 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
371 people viewed this question
old marine
old marine
