Question about Clarion Car Audio & Video
My car has a clarion 401A (1988-91) audio amplifier. I want to know the correct wiring hookup to power and speakers. The FM/Am radio/tape /cd control is kenwood 441? thanks
ajdriver
  • 15 Answers
SOURCE: Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Posted on Nov 14, 2007
  • 16 Answers
SOURCE: car audio
what kind of car is it?
Posted on Dec 21, 2007
SOURCE: Car Radio
I just bought a 3.5 mm aux cord for my ipod but when i press the SRC button, the AUX option does not appear. What am i doing wrong setting this up?
Posted on Jul 14, 2008
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
keemo68
  • 1263 Answers
SOURCE: Clarion radio from 2002 Saab
it i.s apparent that either the button to ingage the wb is not making contact with the module inside or there is a fault on the main board inside the deck. now depending on how old the deck is I would most likely suggest you either have it repaired at an car audio shop or just replace it with a similar unit.. please rate this...thanks
Posted on Sep 28, 2008
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
Since I purchased my 2009 dodge journey I have had an issue with my radio/cd player ... sporadically the volume goes out, if I turn it off, and on it comes right back on, but will only stay on for 20...
AUDIO Any diagnosis of the Audio system should begin with the use of the scan tool. For information on the use of the scan tool, refer to the appropriate Diagnostic Service information.
For complete circuit diagrams, refer to the appropriate wiring information.
AUDIO SYSTEM DIAGNOSIS
CONDITION
POSSIBLE CAUSES
CORRECTION
NO AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Amplifier fuse faulty, if equipped. 1. Check and replace fuses, if required. 2. Wiring to amplifier faulty, if equipped. 2. Verify radio on/off input to amplifier and verify battery and ground connections. Repair wiring as necessary. 3. Radio faulty. 3. Refer to appropriate Diagnostic Service Manual. 4. Amplifier faulty, if equipped. 4. Replace amplifier. NO AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speaker(s) faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty.
5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Power/ground wiring to amplifier open or shorted. 1. Repair wiring as necessary. 2. Power/ground wiring open or shorted. 2. Repair wiring as necessary. 3. Amplifier faulty. 3. Replace amplifier. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speakers faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty. 5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. SOUND DISTORTION (VIBRATION FROM SPEAKER AREA, BUZZING - HUMMING) 1. Door trim panel loose or missing fasteners. 1. Inspect door trim panel and correct as necessary. Replace any missing fasteners. 2. Water shield loose or misaligned. 2. Inspect water shield and adjust as required. 3. Items placed in door trim panel map pockets vibrating or moving from side to side. 3. Remove items from door trim panel. Ensure that vibration is no longer present. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE OPERATIONAL 1. Radio faulty. 1. Refer to appropriate Diagnostic Service Manual. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE NOT OPERATIONAL 1. Fuse faulty. 1. Check radio fuse and Ignition-Off Draw (IOD) fuse in Junction Block (JB). Replace fuses, if required. 2. Radio connector faulty. 2. Check for loose or corroded radio connector. Repair, if required. POOR RADIO RECEPTION WITH KEY IN ACCESSORY OR IGNITION ON POSITION 1. Antenna faulty. 1. Replace the antenna. 2. Radio ground faulty. 2. Check for continuity between radio chassis and a known good ground. There should be continuity. Repair ground, if required. 3. Radio noise suppression faulty. 3. Repair or replace ground strap as necessary. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. 5. Faulty rear window defogger. 5. Verify that the rear defogger grid is functioning properly, repair as necessary (Refer to 08 - Electrical/Heated Glass - Diagnosis and Testing). NO COMPACT DISC OR DVD OPERATION 1. Faulty CD/DVD. 1. Insert known good CD/DVD and test operation. 2. Foreign material on CD/DVD. 2. Clean CD/DVD and test operation. 3. Condensation on CD/DVD or optics. 3. Allow temperature of vehicle interior to stabilize and test operation. 4. Faulty CD/DVD player. 4. Refer to appropriate Diagnostic Service Manual.
Nov 01, 2017 | 2009 Dodge Journey
Hi, I have installed my JVC radio and when it is on FM radio, there is sound through the speakers, but when I play a cd there is no sound.
are you using an amplifier? if so, it sounds like you are using the blue wire (power antenna remote) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. when leaving tuner mode the power antenna wire is turned off.
Feb 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
Need a wiring diagram for DXZ835MP - clarion cd player
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Sep 04, 2009 | Clarion DXZ835MP RB AM/FM/CD/MP3/WMA...
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
I have a fujitsu am/fm/cd/ tape player out of a 93 camry and would like to put it in a 95 camry but the color code for the wiring doesn't match and thats what I need , can you help Thanks John
Hello jrhauber,
The '93 and '95 Camry have identical color codes. Likewise, the vehicle harness connectors are the same.
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
You can purchase an aftermarket wiring harness that plugs into the OEM radio. The part number you need for a 1995 Camry is Metra 71-1761 available here for $9.99.
Hope this helps.
Jun 21, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Need to know how to hook up a sony cd player
see if this helps bro.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony ATRAC MPS/CD/AM/FM Personal CD Player
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Car Audio & Video Logo
102 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
