I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling another cartridge but with same result. When I vacuum out the printer, all is ok for a while but then returns even with an original toner cartridge that I haven't refilled. They can't all be leaking surely?
  • Jonathan Greenstein Mar 25, 2011
    Tahnks, but I've filled Xerox printers successfully for years and it's much cheaper. Equivalent non originals are also an option better than remanufactured
  • 32,281 Answers
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Posted on Mar 25, 2011
My problem is that after refilling the tonner it is giving me low quality of xerox and putting contrast at high initially it was working very nicely please give me right suggession
Please use good quality toner and then try it, it will best to use genuine cartridges, rather than refiiled ones, because that will save your money for a long run.
Aug 28, 2012 | Brother DCP-7030 Digital All-in-One Laser...
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
it sounds like your priming station is full. you would have to spend some money to get it looked at this is not something you want to attempt your self.
Jul 30, 2017 | HP Office Equipment & Supplies
I have and OKI C3400. My printer is showing globs
yuo have a leaky black toner cartridge
take out the cartridge and look for damage
aslo check the fuser for damge or leaks
replace any damaged cartridge
Mar 22, 2010 | OKI C3400n Laser Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
My Minolta Magicolor 2500W printer indicates that it is out of black toner. I have never changed the toner cartridge before and cannot find the instruction manual. (bought it almost 3 years ago...) Do I...
Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
Dec 05, 2009 | Konica Minolta magicolor 2500W Laser...
How do I reset the drum life of a DCP7010
never ver use refil toner on brother products. to answere your first question 1 open the front cover 2 push menue button scroll down to machine info press set buton 3 scroll down to drun lif - push set
Jan 09, 2009 | Brother DCP 7010 Multifunction Laser...
Hp2600n printer
Is the toner fused to the paper, or 'loose', and can be rubbed of easily. Are there 'flakes' of toner, that may or may not be loose?
If the toner is fused, the cartridges are likely to be leaking toner - especially if they are remanufactured - not easy to get right, and even more difficult to get right if 'home refilled'.
Solution to this is replace cartridges, or if these are new return them to supplier as faulty.
If there are 'flakes', it is likely to be the fuser that is contaminated with toner that has ot fused to previous pages - usually as a result of using the wrong type of media, or setting the wrong paper type when printing on thick media.
Fuser can be cleaned, or in extreme cases replaced.
Sep 10, 2008 | HP Color LaserJet 2600n Printer
Not printing extreme right side of page
It is either your drum or open front cover see blue handle @ right hand side pull it out look at rignt hand side of printer and a door has opened (only small) pull the blue lever out and move the pad back andforwards a few times this cleans the glass.
It worked for me but I have to do it fairly often but it samve buying a new drum etc
Jan 08, 2008 | Dell 3010cn Laser Printer
Jammed black cartridge
You may have to force the cart to lock by hand. At worst you may break the cart but it is useless anyway.
Try to avoid as much toner leakage as possible and once out you will have to clean the inside of the machine. Do not vacuum the toner out - it can be dangerous.
In future, don't use refills.
Nov 28, 2007 | Epson Aculaser C1100 Printer
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
96 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
