Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter.
  • Anonymous Mar 17, 2009
    New Friend:
  • 39 Answers
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Posted on Dec 29, 2009
  • Roger Byatt Nov 05, 2012
    Where are the pressure valves How do I recognise them when the machine is taken apart?
  • Sergio M Perez Nov 05, 2012
    You will find the valves between the pump and the expresso heads. They are in-line with the hoses, small and amber in color.
Need Manual for XP2070
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={36EDBCD3-43C5-49F9-916A-09483F86C4FB}&SelectedProdRef=XP2070Click the link and click the Black and Green Icon to download.
Nov 19, 2011 | Krups Coffee Makers & Espresso Machines
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Dec 29, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water goes directly to drip tray instead of to the brewing head.
Have the same issue with mine. Descaled it all and wouldn't even brew with no coffee OR filter in the housing, so I took it in to get it checked out. Turns out it's the solenoid valve that needs replacing. ~$60 part plus $90 labor, so I've decided to try and find that part and DIY, if I can. I'll let you know how that turns out!
Aug 04, 2009 | Krups XP4030 Espresso Machine
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter. I have the exact same problem-that's why I'm on here looking for a solution!
You either have a blocked filter or defective valves. Try the unit without the filter to see if you get liquid out of the group. Most likely you have defective pressure valves (pair) which are not too expensiv to replace.
May 30, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Filter coffee side does not work
I returned the coffee maker at the manufacturer's suggestion
May 11, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
515 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
