Question about Compaq Presario M2000 Notebook
My notebook has flashing lights above scroll and caps lock key's and wont start up for ages I dont know how to fix it do I need to take it somewhere thank you marilyn
  • 114 Answers
Try to hit the F8 and choose to boot on Safe Mode or Last Known Good Configuration.
Posted on Mar 25, 2011
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
BOOTING UP PROBLEM FROM THE BIOS
off the pc .remove the cmos battery and then insert the cmos battery and then again restart the pc and check.
Oct 06, 2008 | Dell Inspiron B130 Notebook
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
I need to lock my fn key but i have been looking online at different ways, such as: using the num lock key and looking for the scroll lock(which i dont think i have on this keyboard), and a fn lock key...
For a start, the user guide shows the scroll lock as being F5 The Num lock key is above the centre of the Numbers key pad
I wonder why you need to lock the Fn Key - except to stop others accessing the useful functions on your keyboard...
The User guide/Notebook tour can be downloaded from here...
http://h10032.www1.hp.com/ctg/Manual/c01482376.pdf
Nov 25, 2010 | HP Pavilion dv7-1132nr Notebook PC
The little lights by the caps lock and scroll/number lock are flashing...I know that if you restart your computer it will stop for awhile, but how can you fix it permanently?
hi colleensousa, to fix it permanently try these steps:
Turn off the pc
remove the cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert the cables and battery on the pc
Turn on the pc
check the caps and num lock if they are continuously flashing on your laptop...
May 20, 2010 | HP Pavilion dv4000 Notebook
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
My scroll lock wont work and i dont know how to make it work
Press and hold the Fn key while pressing the scr lck key. Notice that the Fn key and the alternate keys have a different color (usually blue).
Aug 25, 2009 | Compaq Presario CQ60-220US PC Laptop
The light thats a lock with the letter a starts blinking and it wont boot up. how do i fix this
The blinking light is just a status for the caps light. If the unit does not power on or boot , you may have
A) a low or bad battery, Take the battery out and try to power up just by plugging the unit into the outlet.
B) If that does not work, You may have a loose DC connector on the system board. Unplug the plug from the outlet, then slightly wiggle the connector at the back of the laptopwhere the adapter plugs in. If it moves , the connector is loose on the MLB.
The blue lights located above the keyboard indicate the following:
Turns on when the numeric keypad is enabled.
Turns on when the uppercase letter (caps lock) function is enabled.
Turns on when the scroll lock function is enabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | Dell Inspiron 1501 Notebook
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
Compaq Presario M2000 Notebook Logo
94 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
