Question about Irons
I have got a swan steam generator iron model si4030n and since we bought it the water just squirting out of the iron when i try to use the steam , there was no instructions in the box when i got it so not sure how to fix it please help?????
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
SOURCE: Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Posted on Jan 16, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: Tefal Pro Express Steam Generator Iron
My Tefal is the same, steams for a while then nothing. I have tried to descale with no joy. I think it may be a problem with an internal thermostat that cuts out stopping the steam.
Any ideas????
Posted on Aug 29, 2008
SOURCE: have just bought kenwood steam generator iron but
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Posted on Sep 30, 2009
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
I need a manual for swan steam generator iron item si4030n
http://www.swan-brand.co.uk/swan-2200w-steam-generator-iron-1.html see Documentation http://www.swan-brand.co.uk/media/swan/ib/SI4030N.pdf
Jun 15, 2012 | Irons
Would anyone have the instructions for the SI5040N Swan Steam Generator please? I would really appreciate it. michelle.darker@btinternet.com.
I have just bought a Swan SI5040N and would be able to photocoppy the instructions and let you have them or I can email them.
Jan 01, 2010 | Black & Decker Steam Generator SG200 Iron
STEAM ONLY COMING OUT OF TOP HOLES SWAN S15040
The iron is probably clogged up from mineral deposits in the water. Fill the iron with a 50/50 mix of water and white vinegar. Heat the iron and let it set for awhile. Then steam the solution through the iron. Repeat the process if this does not work. If the Vinegar and water does not work, then try a product such as Lime Away or CLR to remove the deposits. After the iron is cleaned out, try using distilled bottled water in the iron, to reduce the mineral build up.
Hope this helps you!
Aug 15, 2009 | Black & Decker Steam Generator SG200 Iron
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
I have bought a swan s15040n steam generator iron and it does turn on but I can't get to generate any steam. I have tried holding the steam button down for 20 seconds ( and more) but still nothing. Any...
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
Jul 13, 2009 | Black & Decker Steam Generator SG200 Iron
Irons Logo
292 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
