Question about Cycling
I have a Shimano SIS chainset on which has now done 3000 miles hence the teeth are wearng and requires replacement. I've tried using a chainset extractor tool but it will not budge. Is this the correct method - looks like a normal square taper bottom bracket - or can anyone else suggest what to do or where I'm going wrong?
    Brigadier General:
  • 8,546 Answers
Let's see, chain, teeth and bottom brackets. Three different
I think you mean chain rings with worn teeth and you're trying to remove the crankset to get at the chainrings. Crank removal may not be necessary to change the outer rings. In my experience the most-used chainring is the only one that wears out fast. You may be able to just buy one or two rings, or a whole crankset may end up to be more economical, depending on where you shop.
Special tools are necessary for non-destructive removal of the cranks.
Find your style of crank and bottom bracket in here.
http://www.parktool.com/blog/repair-help/categories/crank-service
If your chain is that old that it's wearing the teeth your whole drive train will need replacement - chain, cassette and chainrings. If you keep your chain clean and lubed and replace it before it 'stretches' too much, your expensive drive train parts will last longer.
http://www.sheldonbrown.com/chains.html
Posted on Mar 25, 2011
  • c_rubie Mar 25, 2011
    Yes, the outer ring is the most worn. I've tried to dismantle to see whether separate rings can be removed, but apart from the outer plastic guard, the 3 rings are all moulded/welded as one. The instructions you've linked in are pretty much what I've been trying, so I'll have another attempt with renewed confidence that I'm not missing anything.
    If no joy, I can only assume the crank has somehow "seixzed" to the bracket in the 2 years its been on and seek expert removal?
  • David Dunn
    David Dunn Mar 25, 2011
    The cheaper cranks ARE all one piece because they don't expect the rider to put on the miles or the bike to outlive your enthusiasm for it.
    You would be better off to buy a quality crankset and bottom bracket if necessary (they wear out, too). A Bicycle Shop could hook you up. There are several dimensions that need to be considered for proper chainline and fit.
I have a 2001 Specialized StumpJumper FSR XC and have put a new chain wheel on 48t and I'm struggling to find a front deriailleur that fits any help please?
Clamp on front mech xt or xtr would be an option, be careful if you need bottom pull or top, cut or grind off bracket on old front mech to reinstall,as this is a spacer as well as a mounting bracket ,bit old school but older front mechs are best
Jun 16, 2017 | Shimano Cycling
I need help installing a SHIMANO SIS DERAILER ON MY 2002 Schwinn 10 speed bike
Web search it "install Shimano derailleur" for videos.
Find your exact model here ...
http://techdocs.shimano.com/techdocs/index.jsp
Search for "how to... " just about anything on the web. You don't need Fixya experts for the common stuff.
Aug 13, 2011 | Shimano Cycling
HOW DO I REMOVE A SHIMANO OCTALINK TRIPLE CHAINSET FROM A BICYCLE
You need metric tools, wrenchs and a crank removal tool, both can be bought at a bike shop. Most of us sell Park Tools to customers and they work well, but not cheap. You do not want cheap tools anyway, they only strip your threads. It may end up cheaper to have the shop do it because the tools you need, you probably will never use again. You have to weigh it for yourself.
Aug 09, 2010 | Cycling
Need to replace a Shimano 7 speed SIS rear derailleur for a Quest Omega 21 speed mountain bike
Go to parktool.com/repair for pretty great step-by-step instructions with diagrams and pictures on the procedure. It would be easier to see than to try to tell.
i hope this helps you out,
matthew
Sep 27, 2009 | Shimano Cycling
Cycling Logo
132 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
