Question about FUJIFILM FinePix Z800EXR Digital Camera
I just recently bought a fuji finepix Z800 exr and now i have a lens control error message. what can i do to fix this?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 25, 2011
  • cannycanuck Jun 02, 2011
    I tried all the suggested solutions for my FinePix f200exr but none worked. I had given up and was about to purchase another camera (not Fuji) as the quote to "look at" my 1 1/2 yr old camera was almost $200. Today, giving it one more try before ordering the new camera, I turned my camera on and the same Lens Control Error message appeared. I turned the camera off while holding the lens to prevent it from retracting. I turned my camera on again and the lens retracted, then extended and the error message was GONE! I have taken pictures using zoom and turned the camera on and off several times and it is working well. Hope it lasts and hope this might work for others.
How do I solve problem lens control error?
open your cam, take out the lens unit open it, re assemble the lens.
Dec 31, 2015 | FUJIFILM FinePix F550 EXR Digital Camera
How do i remove lens,to check & possibly replace lens cover.
By carefully dismantling the camera
Take a look at YouTube to see how to dismantle compact cameras and decide if you are happy to give it a go
Jul 15, 2015 | Fujifilm FinePix F660EXR 16MP EXR CMOS...
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Fuji Zoom Error Message
In this link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Fuji FinePix S304 Digital Camera
Zoom Error
If you are still under MFG warranty and bought it from Best Buy they will ship it to service most likely, If you have their service plan they will be able to ship it for service... this needs to be serviced by a professional repair place...
May 16, 2008 | Fuji FinePix A500 Digital Camera
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
Zoom error--again!
Try Fuji website for tech help - looks as if this needs some surgery. If it is a recent purchase they may fix it for nothing - depends where you are.
May 21, 2007 | Fuji FinePix A205 Digital Camera
FUJIFILM FinePix Z800EXR Digital Camera Logo
523 people viewed this question
Top FUJIFILM Cameras Experts
Steve
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
