Question about Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White
Samsung dryer is not drying and its new
I bought a clearance gas dryer at lowes and it is not drying the clothes , it gets warm but not hot enough to dry clothes
  • 4 more comments
  • Anonymous Nov 30, 2008
    I have gone through 2 of the same from Lowes and neither has worked - both the same Samsung gas dryer. Our plumber says nothing is wrong with the gas and connection. I am trying to get Lowes to refund my money and get something else. But, I would rather just get it fixed. Any ideas out there?
  • sims96 Feb 14, 2009
    mitch1156's
    i have the same proplem, we just got the drying installed yesterday and it is not getting hot enough to dry our cloths. I have a repair guy coming next week. please let me know if you find anything out and i will do the same.
    Thanks bill
  • jim destefano Nov 19, 2012
    It seems this unit needs more than adequate venting if your dryer vent is even a little cloged or the run (distance ) is to long it will not get hot.
  • Anonymous Mar 22, 2014
    Dryer will not turn off on timer after clothes are dry? Just continues to run?
  • Anonymous Mar 23, 2014
    my cooling sensor is on and clothes wont dry on any setting. both drying and cooling lights are on
  • Anonymous Mar 27, 2014
    dryer is not getting hot, cooling light is lit up at same time as drying light, wont dry clothes
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
  • 1 more comment
  • cjflanagan Nov 05, 2010
    Oh my gosh - I was convinced that I had a lemon. I had heard such good things about the Samsung and mine (gas model) was only heating to 99 degrees (with a infared thermometer gun). I called Samsung and they asked me if I cleaned the vent pipe and I said yes. After I read this post I disconnected the hose completely and just ran the dryer with no hose to see if better flow would help with the heat. Almost instantly the temperature gun was reading 160 F on a free exahaust! I was charged with new found hope so I hooked up my shop vac on reverse (blow) and my wife went out in the backyard to let me know if anything was happening as I ran the vac. She came in and told me to have a look. I couldn't believe it there was a pile of lint over a foot tall that had collected over the years. I reatached the vent line and the dryer worked perfectly. But the story does not end here. After I pushed the dryer back in place I did not do a good job of watching the exhaust hose and it got some pretty tight corners. Sure enough the temperature dropped again. So I redid my hose making sure that there were no sharp bends and now everything works. I have completely reformed my opinion of the machines after crashing down off such high expectations. I love them and my wife just washed 11 bath towels and 4 pairs of jeans in one load and the dryer had everything toasty dry in 50. Dont give up - clean out that vent line!!!!
  • okiewd Feb 12, 2011
    Thanks for the post, exact same thing happened to me. You saved me a service call and a lot of grief.
  • greatscott
    greatscott Nov 15, 2013
    Thank you! I was having the same problem with my brand new samsung dv400 dryer. cleared out the vent and works perfectly.
Hello All and Hreat info but the best Garunteed way to have a Safe Clear Vent Line is to have a Service Tech Send Special Equipment From Start of line to the End Outside. If the dryer venting is over 12' (Ft) Long with AnY Bends you may need A Booster Fan connected which will also Save Energy, Time
Posted on May 16, 2012
Thank you a 1000x
Posted on Jan 17, 2012
  • Djessop Jan 17, 2012
    Now I need help cleaning my dryer vent. Leaf blower and shop vac did not do the trick.
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Gas Dryer wont get hot enough
Here is a tip about dryers that don't heat right and somethings you can do and check...
Dryer Maintenance
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
May 04, 2010 | Samsung DV448AGE Gas Dryer
2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
Apr 07, 2010 | Samsung DV218AG Gas Dryer
Why is my Frigidaire Gallery dryer not getting hot enough to dry clothing?? It gets warm to te touch but cant dry the clothing within the time settings.
Check out this tip and the other ones at the bottom of that tip...
if you have a gas or electric pick the tip that are for your dryer..
heatman101
Mar 25, 2010 | Frigidaire Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White Logo
10,611 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
