Question about BenQ MP611C DLP Projector
WHY IS THE PROJECTION FROM MY BENQ MP611 DLP IS COLORED VIOLET?
  • 3,400 Answers
One of your input cables us either bad or not seated properly. Remove cable from projector & re-install tightly.
Posted on Mar 25, 2011
BenQ MP 670 black spots
Black spots are more likely to indicate a partial failure of the DLP chip. The lamp cannot produce such a symptom sadly.
Repair will be quite expensive...
Mar 27, 2014 | BenQ Office Equipment & Supplies
Suddenly, benq mx511 has white pixels showing up....multiplying every day...now the projected image consists of 50% snow.
It probably has the same DLP chip as my Mitsubishi television. The mirrors in the chip set get stuck and create the white spots. There is no way to fix this other than replacing the DLP chip.
Feb 04, 2013 | BenQ MX511 3D Projector
Benq MP 721 projector purple colour when it projects.
You are missing one of your primary colors and this is usually to a faulty pin where you are connecting your vga cable to. It could be either the pin on vga port of your projector or it could be the vga cable itself. Please look at the pins especially if you are using one cable to try with all the compputer.
Jun 02, 2010 | BenQ MP721 DLP Projector
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
How do I get the laptop screen to project when I
You can download the manual from the manufacturer's web site at
ftp://downloads.benq.net/projector/manuals/mp620-mp720/mp720-en.pdf
Mar 31, 2010 | BenQ MP620p DLP Projector
I have a DLP Benq projector (not sure the model number); and when I plug my laptop to the the projector I get a "Analog RGB" out of range icon. What do I need to do to get my laptop to be projected again....
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
Sep 08, 2009 | BenQ CP120c DLP Projector
Blue violet ghost
did you just replace your lamp? your balance is probably off.
Jan 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
BenQ MP611C DLP Projector Logo
106 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
