Question about Cycling
My rim of bicyle is bent - Cycling
    Brigadier General:
  • 8,546 Answers
Google this "fix bent bicycle rim" for many answers and videos.
The actual 'fix' will depend a lot on how it got bent. Many bicycle shops can lace a new rim onto your existing hub and spokes but you may find it cheaper to buy a new wheel.
Posted on Mar 25, 2011
Whats causing my rear tire on my 2004 chevy trailblazer wobbles
Check for a bent wheel by fitting another wheel if it is ok the rim will be bent if its the same check for bent axle.
Aug 18, 2014 | Cars & Trucks
I hear a slight rubbing/grinding sound coming from rear brake pedaling the bike. What could it be and how do I fix it?
Most likely the break pad is rubbing intermittently as it rolls because the rim is bent. If its a OEM spoke rim then it wont take many curb jumps to bendit. Most mountain bikes from a walmart or academy wont be anything more than the basic for streets. If you are going off road on real mountain biking trails then you would be better off getting a stronger rim but these can be pricey. Another cause can be that the tensioner springs near the break pads need to be adjusted so you can pull the pad away from the rim. Problem is that it will take some of the stopping power away. Not recommended. Most high end mountain bikes have an actual rotor type disc break like a motor cycle that's on the inner rim so that way even if the rim gets a little bent or wet, the performance of the breaks is still up to par. To check if your rims bent, turn the bike upside down and set it so you can spin the back wheel really fast with the pedals. Then look at the tired from directly behind it. If its bent, you will see the wobble.
Sep 20, 2013 | Bianchi Lynx
Wheel rims are bent
a bent rim besides not hold air will give u a vibration-shake while driving which at higher speed can cause damage to vehicle or can cause loss of control of vehicle if tires are in good shape look around for bone[junk]yards and can get rims probably cheaper than what a tubes can cost you ,
May 21, 2012 | Chrysler PT Cruiser Cars & Trucks
I hit a hole backing out of a driveway and after i heard a noise in the front end from hitting a hole the front tire started to wobble and pull to the left, something is wrong please tell me what
This could be a few things, first try switching a rear tire to the front and see if that helps, you may have bent the rim but you would need to look at it and see is the rim is bent then look at the tie rod end to see if its bent, you could have bent the strut or lower control arm too. i would take a look at the tie rod end and see if its bent, here the thing, you say it wobbles and pulls, a tie rod end or strut or control arm will make the car pull but not wobble, a wobble would be caused by a bent rim or tire witth a bubble and this can make the car pull, tire putting the spare tire on and see if it still pulls and wobbles, if it doesnt then you know its the rim or tire, hope this helps.
Nov 10, 2010 | 1999 Buick Century
Hit the curb on that snow day pretty hard that it bent the rim and chipped some of the hub cap what should I do
If the rim is bent severely, it could cause wear on your tire. If you are unsure of the severity, you might take the vehicle to a tire shop and have the wheel checked on a rotating balance type machine.
Worse case scenario, replace the rim (I'd get one from a wrecking yard). If the hub cap asthetics bother you, the salvage yard may also have one of those.
Hope this helps... Good luck!
Oct 13, 2009 | 2007 Chevrolet Malibu SS Sedan New Cars
Someone sat on it flat and bent rim
well whoever rode the bike with a flat wheel bent the rim. what yoou need now is to buy a whole new rim
Mar 29, 2009 | GMC Denali Boys 24 in. Road Bike
Front End Shake
The most common problem I see with this complaint is a bent rim or rims. So regardless if you balance the tires and rotate them, you will still have a vibration. I assume you have more than one bent rim because it still shakes even after rotation. You will have far more vibration if a bent rim is on the front. That is why people usually rotate a bent rim to the back.
Dec 18, 2008 | 1997 Saab 900
Cycling Logo
81 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
