Question about Kenmore Elite HE4 Electric Dryer
Washer machine problem.
On the last spin cycle water, never stops keeps spraying. Triede different cycles same problem I even disconnected machine in same problem.
  • 750 Answers
Hello noemystotler
You said,
sounds like the timer is not progressing and is defective!
Posted on Sep 19, 2008
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
The washer water does not stop flowing into tub even during rinse and spin cycles. We have to shut off water.
The water is supposed to spray in sporatically during spin...but not steady water spray.
If it's steady for the whole spin it is probably the timer spray signals or the wires from the timer to the spray solenoids.
You may need a diagram to assist in tracing these wires.
I Hope this helps you.
Jun 26, 2011 | Maytag Washing Machines
Water will not fill during rinse cycle water just keeps runningg?
That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
Won't stop filling. When I go through the cycles it continues to fill until I reach the final spin cycle then it will start draining and spin out.
Two common problems for this simptom:
If water stops filling when you disconnect the washer:
Change the pressure switch.
If water keeps coming in after you disconnect the washer:
Change the water valve.
GOOD LUCK MY FRIEND
Aug 30, 2009 | GE Washing Machines
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Washing Machine trouble
The easiest way to solve this without taking the machine apart is to tilt the machine back and look under it.
Above the transmission and clutch you will see the brake assembly. It is a little aggrevating to get to with the cabinet on, but you can spray it with some silicone lube and it will help this problem. You may have to spray it then put into spin, stop it and spray again. After it spins and stops a few times it will usually smooth out.
Nov 05, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Elite HE4 Electric Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
