Question about Acer LXA3706003 Notebook
White screen when booting from hard drive or bootable recovery CD.
  • 90 Answers
Are u able to see Ur BIOS ? If that also showing in white screen Ur display/motherboard/graphics section have technical problem contact service center
Posted on Mar 25, 2011
No bootable device, hit any key
The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
Sep 04, 2014 | Gateway Computers & Internet
With new blank HDD,recovery cd in place,states no bootable device
Does the hard drive show up on your boot order? because if no detection is indicated that would explain why it is not working. Check out my computer to see if C Drive is present, check device manager that it is enabled.
Jun 17, 2012 | Dell Inspiron 8200 Notebook
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
In two years my computer is been on the repair shop four times and everytime they install a new hard drive when I ask what is the problem they don't know why it keep failing. This time is doing the se...
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media.
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form. If your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Jan 07, 2011 | Acer Aspire 5315 Notebook
Laptop wont boot from cd/dvd drive, hard drive is cleasn, no viru
Hi usavahe.
Booting from CD should be possible.
1) When the laptop first starts to power up, repeatedly press the F12 key. This should bring you to a screen that lets you select the boot device.
2) For the Satellite, it may show icons across the bottom of the screen. You want the one that looks like a CD.
3) It should the start to boot from the Windows CD (if it is indeed a bootable disc) and you will see the message "press any key to boot from cd".
4) Press any key you want on the keyboard and the Windows CD installation process should begin
Hope that helps
Feb 12, 2010 | Toshiba Satellite A105 Notebook
Blank Screen - hard drives work and keyboard lights up
Try holding F11 while booting, sometimes this triggers the recovery partition.
Sep 21, 2009 | Compaq Laptop Keyboard for HP Pavilion...
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
Cant go to desktop
no your harddisk is not broken it need fix bed indexing.
For that you need bootable disk or recovery disk .
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then set first boot device as your cd or dvd rom then save settings and exit.
Then put bootable winxp disk or recovery disk in cd rom.
Then press any key to boot from cd.
then follow the procedure then choose recovery console mode.
then type in prompt "chkdsk /r"
then press "y"
then it fix error then check.
If still windows not load then again follow the same procedure and choose repair option then repair your windows .
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Maxtor Hard Drive
Windows doesnt load up stays on this black screen
Most probably it is the problem with your hard drive's MBR (master boot record).
First try booting the system from bootable CD or DVD, if that succeeds that will be the sign that everything is ok with your machine but you have problem with your OS (operating system).
Try reformating the hard disk and resintalling Windows or doing system recovery from CDs provided from your vendor.
To get bootable CD with OS, easiest thing to do is to get one of the linux distributions that can be loaded from the CD.
Smallest and simplest is SLAX.
http://www.slax.org/get_slax.php
Burn it on CD and try booting your computer.
Good luck,
Milan
Jun 01, 2009 | Computers & Internet
Acer LXA3706003 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
