Question about HEWLETT-PACKARD HP 210 Netbook 1.66GHz, 250GB, 10.1" - Lavendar Frost - Netbook (2752490)
I have mobile broadband but i cant get connected. the error message says server proxy needs to be changed. i dont know what to do. i cant get connected to explorer but have a 3g cennection. help
  • 90 Answers
If U r using Internet Explorer from windows Go to Tools -> Internet Options -> Connections -> LAN Settings and TICK automatically detect settings and remove all other ticks from all other boxes.
Posted on Mar 25, 2011
Proxy server firewalled
If using windows,click "internet options" from the control panel screen.Then click "connections" tab. Click LAN stettings tab.Un-check "use proxy server" box
Feb 23, 2014 | Dell Dimension Computers & Internet
In webfreer I cant connect through the net, the error is: A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a...
solution is very easy..open webfreer..open settings..on the left side click extensions..update extensions..and enable secure https proxy
Aug 03, 2013 | Google Chrome
Hi, am using motorola q9h actually i was gifted by my uncle from usa.iam using vodofone service the problem iz that wen i try to connect to the internet its showing cannot connect to proxy server .i am...
dear friend,
this you can ask from customer care they will fix it,if you want to know a proxy server then vote me & leave a comment..
enjoy & cheers
Jan 11, 2011 | Cell Phones
Cant sign in error message 81003004
You simply have to check the connection preferences and check
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself
Hope that helps you
Sep 12, 2009 | Yahoo Messenger
Sign in problem
go to messenger, then click on the connection preference to check if it connect direct to the internet or connect via proxy server if it is on the connect via proxy then may be you need to change the intenet connect by clicking the broadband cable or high speedTI/ LAN
Sep 10, 2009 | Yahoo Messenger
Receiving error 81003004. HELP I can check messages... and have not changed my password, but can not open messenger... suggestions?
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, Example: if Broadband -> broadband(DSL/Cable).
Second Method
If any proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. Need to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Jul 31, 2009 | Yahoo Messenger
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
81003004 error connection yahoo messenger
You can try this:
Goto Connection Prefrences and use a http proxy
Click on Messenger
Select Preferences
Under Category, choose "Connection"
Then, click on the "HTTP proxy" radio button.
Note: You might want to check the internet connection type as well. If you are using Broadband (DSL/Cable), then change it to Broadband (DSL/Cable).
Jun 23, 2009 | Yahoo Messenger
Need Guidance
You cant change your ip yourself, the ip is provided from you internet-provider, but you can go via proxy servers and that way get different ip:s
Or via anonymus server who dont shows your ip at all
Nic
Feb 11, 2009 | AMD Mobile Athlon XP-M 2800+, 2.13 GHz...
Error in installing yahoo!7 messenger 9.0
make sure you have the latest update on software by using windows update
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Oct 20, 2008 | Yahoo Messenger
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
See all HEWLETT-PACKARD HP 210 Netbook 1.66GHz, 250GB, Questions
HEWLETT-PACKARD HP 210 Netbook 1.66GHz, 250GB, 10.1" - Lavendar Frost - Netbook (2752490) Logo
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
