Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I purchased one HP 1522 NF multifunctional printer. Is it possible to print on both side sumultenously. (ie on both side with out inserting paper to print on the second side)
  • HP Master
  • 32,281 Answers
If the printer does not have a duplex unit then it is impossible to print double sided automatically.
Posted on Mar 25, 2011
Print smears when touched on HP M 1522 nf Laserjet printer
This situation is the result of not enough heat to fuser the toner onto the page. The following are the most common causes:
1. Using heavy weight paper or card stock without adjusting the paper type settings. When printer is told it has heavier paper it applies more heat and moves the paper more slowly through the printer.
2. The fuser is failing. If it is all the way across the page then likely bad fuser. If only one section running from top to bottom then it is possible that they fuser fixing film is damaged. This can be fixed without replacing the entire fuser.
3. You have a refilled or remanufactured cartridge and the wrong toner was put in the cartridge. If you have another cartridge try it.
Mar 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
Stampante nf 1522 errore 49 non invia e non riceve fax grazie
49 error is an internal embedded software error.
1) turn off power and wait about 30 seconds, power on and if error comes back, see step 2
2) www.hp.com/support/ljm1522
Jan 14, 2011 | HP LaserJet M1522nf Multifunction Printer...
Humming sound coming from printer
HP LASERJET M1522 NF MFP PRINTE Printer
where is the chip brain, I want to fry it !....It's so dump printer !
Paper is jammed in auto feed of HP 1522 nf. Part of page has rolled onto roller and is barely visisble.
hello check the paper path first pull up the cover of adf u will see the feed rolers clean them & for blokage i think ur problem will be resolved.
Nov 27, 2010 | HP LaserJet M1522n MultiFunction Printer
Sir i have a printer in mfp 1522 hp,thats problem error is Used black cartridges only in always time,but not printing,through my computer,that all ready connected to this computer plz help..
Try doing a nvram. Take out the paper and the toner and turn off, hold down the down arrow and the cancel button and turn the printer back on while still holding. Hold until permanent storage init is displayed.
Al
Aug 24, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to solve error is doc. feeder jam in hp laser jet m 1522 nf
Hello Anil_ kuma61!
First thing you need to do will be check the correct postioning of the pick up roller on the automatic document feeder, open up the top cover, you will see a grey roller on the middle, this roller shouldnt be touching the cork a the bottom.
After checking on this, we need to reset the sensors on the printer, to do this follow this steps:
1) Turn the printer off
2) Take out all supplies, including toner and paper
3) With the printer off, press the down arrow and the cancel at the same time (keep the depressed)
4) Turn the printer on while holding those keys and wait until you a message on the display "permanent storage init"
5) release the keys and wait to the printer to come back to ready
Jan 22, 2010 | HP LaserJet M1522n MultiFunction Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
