Question about Sony Playstation 3 (PS3) Console
My ps3 will play dvd's but not ps3 games (disc read error)? help!
    Novelist:
    Sniper:
  • 51 Answers
Hi murphiesmob,
Yes the disc reading problem on the PS3 is massive!
Let me run through what is going on and how you can fix it:
Cause:
It is the laser that needs readjusting in order to fix this problem. The good news is that the drive will still work as long as you readjust the laser in most cases - so you don't need to replace the drive!
Solution:
You can send it in for Repair and they will fix it for you - although this will cost about $150 in a repair bill and you can expect to wait for about 4 weeks to get your console back.
Quicker Solution:
It is possible to fix the PS3 games reading error from home because as mentioned above all you are doing is readjusting the laser.
Now if you want to go down this route check out the reviews of the top guides and see what they offer first below:
Click Here For Reviews Of The Top PS3 Repair Guides.
Hope this helps!
Posted on Mar 30, 2011
    Novelist:
  • 102 Answers
Does this happen with every PS3 game you try? Make sure the disc is clean and you're putting it in facing the right way. If you can confirm that the disc works, or if the problem occurs on a bunch of different PS3 games, then it sounds like you may have a broken disc drive. Eventually the drive will break completely and not even read DVDs anymore.
There are a few things you can do though, in case it's not a hardware issue. First you should update to the latest firmware. Go to XMB > Settings > System Update, run it and follow any on-screen instructions.
If that didn't fix the problem then you should next backup all of your PS3's data. The next couple of things I suggest will cause data loss, so it's nice to store it now so you can have all your data back when you fix the issue. To backup your data, run the Backup Utility
(XMB > Settings > System Settings > Backup Utility). Choose the restore option and follow the on-screen instructions. You'll need a fairly large storage device (USB hard drive, flash drive, etc). If you're confused, check out Sony's official page on the utility.
With your data backed up, try the different options in Safe Mode. This link will show you how to access it. Try options 2, 3, 4 and 5, in that order, and see if it's reading discs in between each one. Anything after 2 will delete your data; thus the need to make a backup.
If that doesn't work, you'll probably have to send in your PS3 for repair. It costs 150$ unless you're under warranty. It's a pretty simple process; you submit the repair request, Sony sends you a box to send your PS3 in, then they send you a working one back. Unfortunately this process will take a month or two. I know from experience with a similar issue.
Hope this was helpful!
Posted on Mar 25, 2011
SOURCE: ps3 read errors
There is a fault with the laser unit in the PS3. This is similar to the PS2 DRE problems and usually replacing the laser fixes it.
Jon
Posted on Oct 15, 2007
bubulica2000
  • 55 Answers
SOURCE: ps3 not reading disc
the Diode in the PS3 units actually has 3 diodes built in. Looks like your blu ray one went bad the other 2 still function.
Order a replacement KEM-400 AAA and replace it (the whole laser lens mechanism with deck). If you still have warranty send it in.
Posted on Sep 05, 2008
  • 4 Answers
SOURCE: PS3 80 GB - Error Code 8002991
Hi tomdonnatim,
If your PS3 is brand new, you most likely have to update the system's software to a more current version in order to properly play many Blu-Ray discs.
In order to update your PS3 system:
Go to the home menu, move to the "Settings" tab (the 2nd tab from the far left), scroll down to "System Update". It takes about 5 minutes to download and fully download the update, but it should solve the problem.
More information on the system update can be found below:
http://www.us.playstation.com/ps3/about/systemupdate
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: PS3 won't read dvd game.
mabey there is a scratch on the disc or its the wrong type of game
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: ps3 wont read any game but will read dvd
Try downloading the update.
Posted on May 28, 2009
Ps3 only plays ps2 games
the read files are corrupt for bluray and DVD discs.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont play game but will play DVD's
The laser in the dvd drive requires different strengths to read different discs. If its reading movies and not games then the laser is starting to go bad in it. You can either replace the laser if your tech save to open up the ps3 and opening up the dvd drive, or you can just get another drive to put in there. Either one you can get from Ebay fairly cheap.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
I have a 40 gb ps3 ...it can play dvd videos but can't play games
Your laser might be damaged or dirty. Try following the instructions here: http://www.xtremeps3.com/2009/07/28/im-getting-disk-read-errors-how-do-i-fix-it/
Aug 01, 2009 | Video Game Consoles & Games
Read disc error
Same problem here, your only option is to send it in to sony.  I'm about to click submit with my card information to pay the fee.  Mine reads everything but blu ray games and movies.  If yours is over a year old it's probably out of warranty like mine unless you bought the extended warranty.  For you crlnmcgrth, i would check and see if you can find out when you bought yours exactly.  If you are still under warranty sony will fix it for free or send you another system identical to yours for free.  Call 1-800-345-sony.  They open at 9 am est or 6 pst. Hope this helps.
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 not reading discs
PS3 is The amazing device by sony but it has some common problems like Disc read error etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Aug 27, 2008 | Sony Playstation 3 (PS3) Console
Disk reading error
your cs drive is probably dead(the laser module anyways) you will probably need to return the ps3 to sony and get a new one.
Aug 09, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't read game discs or DVDs
no mate u need 2 send your ps3 back 2 sony this happened 2 me mate they havent got a solution 4 it they believe that the blu ray laser has burnt out meens you play 2 much lol
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not reading disc
See if a DVD works. For me, I know my Bluray is ruined because I can watch DVDs and play PS2 games fine but anything Bluray does not work. If a DVD does not work, you have more of a problem, if DVD does work you need a new BlueRay which Sony should take care of for you. If you don't have receipt, etc. like me you can buy a new Bluray (KES-400AAA) on Ebay and use this guide to install it http://edpsystemssupport.com/index.php?option=com_content&task=view&id=29&Itemid=45.
Hope that helps.
Apr 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
96 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
