Question about Channel Sources Namo Interactive WebEditor 5.5
Hi, i'm using Namo Active Square 7, with Internet Explorer 9, but when compose email, I cannot paste (Ctrl V), if I want to add something, must right click and choose "Paste Text", cannot paste some cells from Excel files Pls assist on how to solve this Thank you
How do I change the original default setting for no add ons mode?. Originally specified when installing iexplorer 9, windows 7
You can use Internet Explorer with no-addons by going to Start/All Programs/Accessories/System Tools/Internet Explorer (No add-ons).
There are no except Flash.
Jan 20, 2013 | Microsoft Internet Explorer 9
Tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    [Alt] and letter Select menu item by underlined letter
    [Ctrl] and [Esc] Open Program Menu
    [Ctrl] and [F4] Close active document or group windows (does not work with some applications)
    [Alt] and [F4] Quit active application or close current window
    Ctrl] Lft., Rt. arrow Move cursor forward or back one word
    Ctrl] Up, Down arrow Move cursor forward or back one paragraph
    [F1] Open Help for active application
    Windows+M Minimize all open windows
    Shift+Windows+M Undo minimize all open windows
    Windows+F1 Open Windows Help
    Windows+Tab Cycle through the Taskbar buttons
    Windows+Break Open the System Properties dialog box
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 | Computers & Internet
    Tip
    Most Often Used Keyboard Shortcuts.
    Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system.
    Some More RUN menu Commands.
    1. iexplore + "web address" = Internet Explorer
    2. compmgmt.msc = Computer Management
    3. dhcpmgmt.msc = DHCP Management
    4. dnsmgmt.msc = DNS Management
    5. services.msc = Services
    6. eventvwr = Event Viewer
    7. dsa.msc = Active Directory Users and Computers
    8. dssite.msc = Active Directory Sites and Services
    9. devmgmt.msc = Device Manager
    10. msinfo32 = System Information
    11. cleanmgr = Disk Cleanup
    12. ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    13. mmc = Microsoft Management Console
    14. excel = Microsoft Excel (If Installed)
    15. msaccess = Microsoft Access (If Installed)
    16. powerpnt = Microsoft PowerPoint (If Installed)
    17. winword = Microsoft Word (If Installed)
    18. frontpg = Microsoft FrontPage (If Installed)
    19. notepad = Notepad
    20. wordpad = WordPad
    21. calc = Calculator
    22. msmsgs = Windows Messenger
    23. mspaint = Microsoft Paint
    24. wmplayer = Windows Media Player
    25. rstrui = System Restore
    26. netscp6 = Netscape 6.x
    27. netscp = Netscape 7.x
    28. netscape = Netscape 4.x
    29. waol = America Online
    30. control = Opens the Control Panel
    31. control printers = Opens the Printers Dialog
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
    Will add some more soon .. Hope its helpful for you guys.
    on Dec 19, 2009 | Computers & Internet
    My internet explorer 9 is always shutting down without apparent reason, especially when trying to share a video from youtube onto facebook
    I would suggest for the meantime to move back to IE 8 as there are lots of issues with IE 9 as of today July 15, 2011. I wrote down information how to put it back to IE8.
    1.Go to the Add or Remove Programs section of the Control Panel. In Windows 7 you will find this just below the address bar when you open my computer. 2. On the Add or Remove Programs make sure to show updates 3. When the list has been populated, scroll down until you find the Internet Explorer section 4. Remove/uninstall Internet Explorer 9 leaving the Internet Explorer 8 on the list 5. After completing the removal, reboot your computer You should now have Internet Explorer 8 active on your system.
    Jul 16, 2011 | Microsoft Internet Explorer 9
    How to down grade my ie to ie8
    Jul 12, 2011 | Computers & Internet
    Help, I am using RR as my email. I also use Internet Explorer, Google Chrome and Firefox as my browsers. My email is a different size in every browser. Mostly, it is at 9 pt. I am tooo old to read that....
    If you hold Ctrl key pressed and scroll up/down (mouse scroll button or the side bar of the touchscreen, if laptop) the text in your browser will increase/decrease in size.
    Jun 13, 2011 | Microsoft Windows 7 Home Premium 64BIT...
    I lost my email from the toolbar when i downloaded explorer 9
    In IE 9 the Internet Mail button has been replaced by the "Read Mail" button (looks like a mail envelope) which works like the old Internet Mail button in older versions of Internet Explorer. If the "Read Mail" button is not on your command bar in IE 9, you can add it as follows:
    1. Open Internet Explorer.
    2. Right click the Command bar (Where you see the icon for Home on the right)
    3. Point to Customize and then left click on Add.
    4. Under the Available toolbar buttons, left click "Read Mail" and then click on Add.
    5. Click Close.
    Changes will appear immediately. I hope this has been helpful and thanks for using Fix Ya.
    May 09, 2011 | Microsoft Internet Explorer 9
    How do i get cut copy & paste on windows 7
    There are standard keyboard options are available for cut, copy and paste operations. These are bydefault enabled in all type of windows based softwares.
    Cut - > Ctrl + X
    Copy - > Ctrl + C
    Paste - > Ctrl + V
    Above type of operations are allowed in all type of Windows Versions (95 / 98 / NT / 2000 / 2003 / XP / Vista / 7)
    Thanks,
    Amar
    Oct 07, 2010 | Microsoft Computers & Internet
    CAN READ E-MAILS BUT COMPOSE FACILITY MISSING
    try changing the browser if you are using internet explorer 6 or even 7 . IE6 is no longer supporting some new features well. try Firefox, Safari or Chrome. if that does not help, please comment here.
    Oct 01, 2009 | Yahoo Mail
    Yahoo email will not compose or move mail, continuously loading
    Press [Alt] + [T] + [O]
    Choose the Advanced tab from the menu.
    Click on the [Reset] button below the Reset Internet Explorer Settings b section.
    Close Internet Explorer.
    Remove all versions of JRE (Java Runtime Environment).
    Install JRE 1.4.2_08
    Open Internet Explorer and open the Yahoo mail page.
    Hopefully you should now be able to compose new mails and view the existing emails.
    Apr 16, 2009 | Computers & Internet
    Channel Sources Namo Interactive WebEditor 5.5 Logo
    239 people viewed this question
    Top Channel Sources Computers & Internet Experts
    David Payne
    David Payne
    Are you a Channel Sources Computer and Internet Expert? Answer questions, earn points and help others
